Insite + Nexiq on My '99 and '01 Dodge – What's Going Wrong? - Printable Version +- auto-epc.org (https://www.auto-epc.org) +-- Forum: FREE Zone (https://www.auto-epc.org/forumdisplay.php?fid=155)+--- Forum: Diagnostic & Workshop Manuals (https://www.auto-epc.org/forumdisplay.php?fid=157) +--- Thread: Insite + Nexiq on My '99 and '01 Dodge – What's Going Wrong? (/showthread.php?tid=17111) |
Insite + Nexiq on My '99 and '01 Dodge – What's Going Wrong? - Martin56 - 05-29-2025 I’ve got access to Caterpillar, Detroit, Volvo, and Cummins diagnostic software at work, and we use the nexiq 2 usb link across all of them without any issues. I recently purchased a Nexiq adapter to use with my personal Dodge/Cummins trucks. The setup I’m working with: 1999 Dodge: Has the triangular 3-pin connector near the ECM. 2001 Dodge: Has the flat 3-pin connector, also near the ECM. The Nexiq adapter I bought only includes the triangular 3-pin connector — not the flat 3-pin that my 2001 harness uses. Issue I tried connecting to the ECM on my 1999 Dodge using the triangular 3-pin connector, but it wouldn’t work. In fact, it triggered a Check Engine Light with a communication code error. I was able to clear that code using another tool I have. I also tried plugging into the datalink port where my Quadzilla tuner is connected, still no luck. I noticed that the 3-pin triangular connector on the truck only has two wires populated. What Am I Doing Wrong? Why can’t I communicate with the ECM? Is the missing wire the issue? Do I need a different adapter for full compatibility with these older Dodge trucks? Any help would be appreciated from those who’ve had success reading the ECM on a '99 or '01 Dodge using Insite and Nexiq. |
