Becker MAP PILOT Europa V14 (2017) (Q2.2016) - Printable Version +- auto-epc.org (https://www.auto-epc.org) +-- Forum: Air-Bags - Satellite Navigation - Dash (https://www.auto-epc.org/forumdisplay.php?fid=48)+--- Forum: Cars Satellite Navigation systems (https://www.auto-epc.org/forumdisplay.php?fid=50) +---- Forum: Mercedes Benz (https://www.auto-epc.org/forumdisplay.php?fid=274) +---- Thread: Becker MAP PILOT Europa V14 (2017) (Q2.2016) (/showthread.php?tid=7887) |
Becker MAP PILOT Europa V14 (2017) (Q2.2016) - Admin - 01-04-2017 Becker MAP PILOT Europa V14 (2017) (Q2.2016) Including Becker MAP PILOT Software + hazardous points-Warner Europe September 2016 + Funny voice: Darth Vader (ger) + Tunnel Sight Pro The map data and extension (s) from the Download function ONLY in conjunction with the already modified the download ID, -So NOT WITH YOUR OWN !!! Update works without "firmware changing" and without "write protection"!? You have to delete all data from your BMP and then you have to copy ALL data from the unpacked update into the root directory your BMP's BUT FIRST save all of your original data. After this you have to do the complete procedure again like this: You have to download all files for the update and after this you must unpack them. After you have saved your original files of the BMP, delete ALL files of the BMP. formatting BPM is not necessary Then copy ALL data („APD“, „MapRegionsPSF50“, „Navi“, „device.xml“ e.g.) from the update into the root of BMP. DO NOT TOUCH (MODIFY) ANY FILES! Finally you can go to your car and you will see everything is ok...? IMPORTANT ::: USE WINRAR V 5,XX does not extract with JDownloader (For the 4GB models copy the folders APD, MapRegions SF50 and Navi to the SD and the rest to the Becker Map pilot) |
