Latest news: --- Caterpillar ET Electronic Technician 2019C v1.0 [10.2019] --- Cummins INCAL - ECM Calibrations [04.2020] + (RMI) + (SIR) --- Perkins EST 2018A v1.0 [01.2018] + LICENCE --- Subaru Select Monitor 4 v18.1.0 [07.2019] --- ODIS Service 5.1.6 + ODIS Engineering 9.2.2 [2019] VMware --- ODIS-E Flash files (Flashdaten) [11.2019] --- Caterpillar ET Electronic Technician 2019A v1.0 [01.2019] --- Mercedes DAS XENTRY OpenShell XDOS 26.9.3.2 [03.2020] --- JCB Service Manuals FULL [2017] --- JCB ServiceMaster 4 v1.81.1 [07.2019] FULL --- JCB ServiceMaster 4 v1.81.2 [02.2020] FULL --- Mitsubishi MUT-III PRE 20011-00 Diagnostic Software [2020] --- GM MDI Manager v8.1.135.13 [2015] --- MAN Mantis v.606 EPC [03.2019] --- Renault CAN CLiP v195 [03.2020] --- IVECO Power Truck + Bus Q1 [02.2019] --- BMW PSdZData v4.20.11 Lite [2019] --- Renault DDT2000 Diagnostic Tool DATABASE [12.2019] --- Mazda 6 Service Repair Manual + Wiring Diagram [2014-2019] --- Caterpillar SIS 2019 DATA [01.2019] FULL ---
GM
[Image: gm_logo.jpg]
The MDI Manager is a software utility that allows you to configure the MDI and also perform occasional maintenance operations, such as downloading updates to the unit’s internal software. The MDI Manager software running on a PC is designed chiefly for IT professionals working in a shop environment, or for anyone tasked with setting up one or more MDIs for general use.
The tester’s or unit’s internal software (sometimes called firmware): This is the software that runs on the MDI itself.
The MDI Manager software: This is the software running on your PC that allows you to configure the tester for use in the shop. The help file you are currently reading explains how to use this software, while the MDI Quick Start Guide and the MDI User’s Guide discuss the operation of the tester itself.
Mega.NZ Links | Single Extraction | Real Screen Shots
GM MDI Manager v8.1.135.13 [2015].txt
