SCANIA Multi [10.2015] Multilanguage
Win | 7.52 GB
Year / Release Date: 2015/10
Version: 6.16.1.1
Developer: Scania CV AB
Developer website: http://www.scania.ru/
Language: Multilingual
License: Freeware
Description: The program SCANIA MULTI contains information about spare parts for cars and buses Scania. All information is presented since 1985, for trucks, buses and chassis series SCANIA, for all regions (differ with the equipment and execution).
Service documentation in English and Russian languages.
Extras. Information: The distribution disc 2: Documentation for repair and spare parts.
Starting with version 2014.02 does NOT work in Windows XP.
Requirements:
- Hard Drive: 10 GB of available space
- DVD-ROM
Installation:
Scania (Starting with version 2014.02 does not work in Windows XP)
1. Mount disk 1 (Disk1.iso).
2. If you have already installed NET Framework 4 or fresh - skip this step.
Run dotNetFx40_Full_x86_x64.exe of Util folder to mount the disk. Looking forward ->
Put the check on I have read blablabla ... -> Install -> We are waiting for -> Finish
3. Run setup.exe from the disc mount. Put the check Accept the license ... -> Remove daw with Acrobat Reader ->
OK -> point stands on the Install application and data, the way I change C: \ Program Files \ Multi \ to c: \ Auto \ Scania,
where C: \ MultiDat changing to c: \ Auto \ Scania \ MultiDat, Will ask several times about creating directories ->
Next -> Install -> Next -> I accept ... -> Next-> Next -> Install -> Finish -> Long wait. -> Close.
4. Those who are relevant repair information necessary to mount a drive (Disk2.iso).
Run setup.exe from the disc mount. -> Next -> We are waiting for a long time -> Ok
5. In the Start menu -> All Programs -> Accessories -> Command Prompt ->
echo sp_password NULL, 1234, ’sa’ | OSQL.EXE -S localhost\MULTI_SQL -E
echo use Multi_1510_NonEU; update multi_proparameter set text="*').$,#(" where item='PROD_STAMP' | SQLCMD.EXE -U sa -P 1234 -S localhost\MULTI_SQL -d Multi_1510_NonEU
In the start menu in the folder have Multi Multi Config, tab settings -> change language -> Apply -> Close.
If I helped you - please press Thanks and Rep
Original activation keys for any version of the program Techstream.
