Microsoft Windows 10 PRO 1511 Build 10586 OEM June 2016 FULL
Microsoft Windows 10 PRO 1511 Build 10586 OEM June 2016 FULL [TechTools]
Windows 10 is so familiar and easy to use, you’ll feel like an expert. The Start Menu is back in an expanded form, plus we’ll bring over your pinned apps and favorites so they’re ready and waiting for you.
The “definitive” operating system by Microsoft arrives at 1511 version and is updated to build with a 10586 installation process that requires a few minutes to be completed. New products are primarily under the shell, with performance improvements and optimizations in the code, but there are a few adjustments on the side of the feature.
Windows 10 is designed to be compatible with the hardware, software, and peripherals you already own. And always-enabled updates help you stay current on features and security for the supported lifetime of your device. Windows 10 gives you absolutely the best experience for doing what you do. Stay focused with easy ways to snap apps in place and optimize your screen space for getting things done. See your open tasks in a single view and create virtual desktops to gain space or group things by project, like Office apps for work and games for play.
Version:
Windows 10 PRO 32Bit
Windows 10 PRO 64Bit
Languages:
English,French,Arabic
Activation:
Its Pre-activated, no crack or key needed
| How to use |
1) Open _ReadMe.txt and read Instructions
Version:
Languages:
Activation:
| How to use |
Hit the buttons if this post help's you !!!
