Honda HDS v3.102.038 + ECU Rewrite [10.2017]
Honda
Honda HDS 3.102.038 + ECU Rewrite [10.2017]
FULL Pack
Dealer diagnostic software for Honda & Acura
[Image: image.jpg]
[Image: image.jpg]
[Image: image.jpg]
[Image: image.jpg]
[Image: image.jpg]
[Image: image.jpg]
Quote:Region: USA + Canada
Version: 3.102.038
Platform: WinXP, Vista, Windows7, WIN8, WIN10
Year: 2017
Date of update: 10.2017
Dealer diagnostic Honda & Acura. Includes versions for PC, HDS Pocket Tester. Contains a calibration Honda and Akur USA + Canada.
CM Update ECU Rewrite
Diagnostic System
Device manger
OBD Scantool
Teradyne Wireless Card Manager
Screen Capture
Unit Conversion Tool
Markets:
USA
Canada
Europe
General
Japan
This software turns your laptop or desktop computer into a functional diagnostic system tool capable of reading OBD diagnostic codes.
Honda functions include:
•DTC reading and clearing
•Snapshot function (capture data relative to a trigger event)
•Vehicle data display (value, line graph, or bar graph formats)
•DLC locator diagrams
•Data list display (real-time display of ECU parameters)
•Onboard tutorial
•Generic scan tool runs basic tests on non-Honda/Acura vehicles (HDS Tablet and Pocket Tester only)
•Control module update functions (HDS Tablet and Pocket Tester only)
Hardware and software requirements:
•PC or laptop with either Windows 2000 Professional (SP4 or later) or XP (SP1 or later)
•Hard disk drive with at least 400MB of free space
•CD-ROM drive (if a high-speed Internet connection is not available)
•Type II PC card drive (HDS Tablet only)
•RS232 port required to connect PC to HIM (PC version software only)
•Monitor capable of displaying in VGA mode or above (1024 x 768 recommended)
•Internet connection (high-speed connection recommended)
Communication Interface:
Quote:HIM / GNA660
NOTE: this program works only with the diagnostic interface GNA600 or HIM.
.txt   Honda HDS v3.102.038 + ECU Rewrite [10.2017] MegaNZ Links.txt (Size: 541 bytes / Downloads: 4)
.rar   Install Instructions + Fixes.rar (Size: 21.22 KB / Downloads: 6)
Install error with folder CMU PROG files can you check.
(12-20-2017, 01:58 AM)craneauto Wrote: Install error with folder CMU PROG files can you check.
One setup.exe file can not run setup two time, can you check again.
Honda Honda HDS, I-HDS, ECU Rewrite, Immobilizer Tool Admin 0 1,683 01-03-2022, 01:47 AM
Honda Honda HDS 3.103.048 + ECU Rewrite [2020] Admin 0 7,277 02-20-2020, 05:10 AM
Honda Honda HDS 3.103.023 + ECU Rewrite [11.2018] FULL Admin 0 5,987 02-11-2019, 06:58 AM
Honda Honda HDS 3.102.054 + ECU Rewrite [10.2018] Admin 0 4,463 10-16-2018, 01:20 AM
Honda Honda HDS 3.102.051 + ECU Rewrite [03.2018] Admin 0 4,951 05-06-2018, 10:41 PM
Honda Honda HDS 3.102.029 + J2534 ECU Rewrite [07.2017] Admin 0 6,379 11-07-2017, 07:42 AM
Honda Honda HDS v3.101.044 + ECU Rewrite [12.2016] Admin 0 3,356 03-22-2017, 09:07 AM
Honda Honda HDS 3.101.015 + ECU Rewrite [06.2016] Admin 0 6,200 07-01-2016, 01:15 AM
Honda Honda HDS 3.016.033 + ECU Rewrite [2015] Admin 0 6,444 08-25-2015, 07:16 PM
