Renault CAN CLiP v185 [02.2019] - Printable Version +- auto-epc.org (https://www.auto-epc.org) +-- Forum: The Normal Main Forum (https://www.auto-epc.org/forumdisplay.php?fid=5)+--- Forum: Cars (Light Vehicles) (https://www.auto-epc.org/forumdisplay.php?fid=7) +---- Forum: Renault - Dacia (https://www.auto-epc.org/forumdisplay.php?fid=195) +---- Thread: Renault CAN CLiP v185 [02.2019] (/showthread.php?tid=10808) |
Renault CAN CLiP v185 [02.2019] - Admin - 02-28-2019 Renault CAN CLiP v185 [02.2019] Renault Diagnostic Tool. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Quote:Region: All Region Renault CLIP - the latest diagnostic tool from Renault. It contains all the latest diagnostic technology and information base to address all issues. Extras. Info: If the primary installation, follow the instructions, which is attached. If you already have an earlier version, it is recommended to uninstall and then follow the installation instructions. It only works with original CLIP adapter or with a Chinese clone, no adapters and KL KKL is not supported. Code: Renault has developed a diagnosis system called Valise Clip. Hooked up to the car through OBD2 connector, it runs a complete test automatically, checking a series of parameters and identifying problems that can then be solved.Starting with version CLIP 173, Windows XP is no longer compatible with CLIP. TORRENT FILE | Single Extraction | Real Screen Shots Password: auto-epc.org |
