PSA Diagbox 8.55 [v07.855] (VMware) 2019 - Admin - 05-15-2020
Diagnostic program for PEUGEOT & CITROEN Cars.
![[Image: 01.jpg]](https://i.postimg.cc/sxMhvDgv/01.jpg)
Diagnostic program used by dealers for Peugeot and Citroen vehicles. It only works with the original Chinese and adapters XS Evolution Lexia3.
You can do all as an authorized dealer. This diagnostics software allows you to perform a complete analysis of all models from 1995 to present. Diagnosis is made through the OBD II connector (which is located near steering wheel) or via manufacturer-specific connector (only older cars, pre-2001).
Installing DiagBox 8.01 requires an OS of at least Windows 7 x32 and 22.5 GB of free space
Quote:content includes: VMware 12 image with XP Pro SP3 32bit English and pre-activated Diagbox 8.55 (v07.855) Multilanguage ; as well as VMware 12 image with XP Pro SP3 32bit English
Part 1: VMware 12 image with XP Pro SP3 32bit English and pre-activated Diagbox 8.55 (v07.855) Multilanguage
- VMware 12 image with XP Pro SP3 32bit English
- Diagbox 8.55 (v07.855) Multilanguage | 09/2017 (20 languages: Chinese, Croatian, Czech, Danish, Dutch, English, Finnish, French, German, Greek, Italian, Japanese, Hungary, Polish, Portuguese, Russian, Slovenian, Spanish, Swedish and Turkish)
- PSA XS Evolution Interface Drivers
- PSA XS Evolution Interface Automatic Firmware 4.3.7 updating, Launcher_850 by Simple
- Diagbox Language Switcher
- Diagbox Killer
- PSA Interface Checker + All Firmware's from 2.0.1 to 4.3.7
- Backup APPDIAG.sys activation file in Desktop
Diagbox 8.55 (v07.855) Desktop-01 Diagbox 8.55 (v07.855)-02 Diagbox Language Switcher-03 Diagbox APPLI Software-04 PSA Interface Checker + Firmware 4.3.7-05
Info of Launcher_850:
Contents of the "C:\AWRoot\bin\launcher" folder, this release includes firmware versions:
LX = Lexia and PP2000
DB = DiagBox
APPLI.COM
APPLI_4.2.0 LP.COM
APPLI_4.2.2 LP.COM
APPLI_4.3.0 DB.COM
APPLI_4.3.2 DB.COM
APPLI_4.3.3 DB.COM
APPLI_4.3.4 DB.COM
APPLI_4.3.5 DB.COM
1- Make a backup of all files in your "C:\AWRoot\bin\launcher" folder, no need to include folders inside \launcher.
2- Extract all files of the "launcher850.zip" into "C:\AWRoot\bin\launcher" overwriting existing files.
3- Connect your XS Evolution VCI and start DiagBox
4- DiagBox will check current firmware version and (upgrade/downgrade) using the file APPLI.COM, if necessary.
To change the Firmware version, rename the desired Firmware file from APPLI_X.X.X.COM to APPLI.COM.
launcher850.zip (into torrent)
The update function can be disabled by setting "MAJ_COM=TRUE" to "MAJ_COM=FALSE" in "C:\AWRoot\bin\Launcher\ap.ini"
In case reverting to the original setting is needed,
1- Delete all files (only) inside "C:\AWRoot\bin\launcher".
2- Restore backed-up files back to their original state.
