Adjustable Low Idle Speed on Cummins INSITE Software - Printable Version +- auto-epc.org (https://www.auto-epc.org) +-- Forum: FREE Zone (https://www.auto-epc.org/forumdisplay.php?fid=155)+--- Forum: Diagnostic & Workshop Manuals (https://www.auto-epc.org/forumdisplay.php?fid=157) +--- Thread: Adjustable Low Idle Speed on Cummins INSITE Software (/showthread.php?tid=15433) |
Adjustable Low Idle Speed on Cummins INSITE Software - Martin56 - 11-06-2022 Adjustable Low Idle Speed on Cummins INSITE Software Adjustable Low Idle Speed This feature can reduce the amount of fuel burned and decrease cab noise and vibration. The Low Idle speed can be set to the desired value using INSITE™, however the Operator can override this value using an OEM-supplied idle speed adjustment switch. Low Idle speed is controlled by the low idle governor which prevents the Engine speed from dropping below a predetermined value by controlling Engine fueling. The default Low Idle speed is defined by the calibration. The Low Idle speed adjustment switch enables the driver to adjust the Low Idle speed using a two-position momentary toggle switch. Pressing and releasing the switch in one direction raises the Low Idle speed by a calibrated increment, such as 25 RPM, and pressing and releasing the switch in the other direction lowers the idle speed by the same calibrated increment. When the switch is held in either adjust position, the idle speed gradually increases or decreases by the calibrated increment. #Features and Parameters (1). Adjustable Low Idle Speed When enabled, this feature allows the user to configure Low Idle Speed. (2). Low Idle Speed This allows the user to set the Engine idle speed that will be maintained when the accelerator pedal or lever is released. →Changing Setting Low Idle Speed with INSITE: A). Double click on the ECM Value to change, and use the keyboard to edit the current value (800 RPM). B). Sending to ECM: click the Send to ECM button on the toolbar, or select Send to ECM on the right click menu, or through File menu – Send To – ECM… C). Click OK on Confirm ECM Adjustment window to continue. D). Key Switch window displays: Please turn the Key Switch off, and then click OK. Key Switch/ Ignition Switch need to turn OFF. E). Key Switch window displays – Action: Waiting 30 seconds before allowing for Key On. F). Turn Key Switch On window displays: Please turn the Key Switch on, then click OK. Key Switch/ Ignition Switch need to turn ON. G). ECM Write Succeeded window displays: All parameters were written successfully to the ECM. Click OK. (3). Low Idle Speed Additional Settings When enabled, the following additional settings are available. (4). Step Size This parameter is used to set an incremental change in acceleration or deceleration. The operator can adjust the idle speed in 25 RPM increments if an OEM-supplied idle adjustment switch is installed. #Interaction with other Features and Parameters: A Low Idle Adjustment Switch monitor parameter is provided to help diagnosis issues related to the low idle adjustment switch. The monitor has three states: Increment — The Low Idle Engine speed is increasing. Decrement — The Low Idle Engine speed is decreasing. Center Off — The Low Idle adjustment switch is in the normal or center position. When increasing the Low Idle Engine speed, the Low Idle Adjustment Switch parameter will indicate Increment. When decreasing the Low Idle Engine speed, Low Idle Adjustment Switch parameter will indicate Decrement. When the low idle adjustment switch is in the normal or center position, the Low Idle Adjustment Switch parameter will indicate Center Off. →Incorrect adjustment of the low idle speed may cause excessive vehicle vibration or slightly decreased fuel economy. For more information, please follow https://www.obd2.ltd |
