The Best Truck Diagnostic Tools in 2023 - Printable Version +- auto-epc.org (https://www.auto-epc.org) +-- Forum: FREE Zone (https://www.auto-epc.org/forumdisplay.php?fid=155)+--- Forum: Technical Repair Info (https://www.auto-epc.org/forumdisplay.php?fid=158) +--- Thread: The Best Truck Diagnostic Tools in 2023 (/showthread.php?tid=15858) |
The Best Truck Diagnostic Tools in 2023 - Martin56 - 05-30-2023 The Best Truck Diagnostic Tools in 2023: 1. John Deere Service Advisor 2. Noregon JPRO Professional Truck Diagnostic Scan Tool 3. CAT Caterpillar ET Diagnostic Tool 4. New Holland Electronic Service Tools 5. Volvo Vocom 88890300 V2.8, Development Edition 6. Perkins EST Interface 7. JCB Electronic Service Tool 8. WABCO DIAGNOSTIC KIT 9. NEXIQ USB Link 10. Cummins INLINE 6 and Cummins INLINE 7 11. Jaltest Diagnostic Truck Set 12. Scania VCI3 Diagnostic Tool 13. TEXA Truck and Trailer Diagnostic Tool 14. MAN T427 with MAN CATS3 15. Mitsubishi MUT-3 diagnostic tool 16. XTOOL D8 Diagnostic Tool 17. Deutz Diagnose Kit 18. Autel Maxisys MS909CV We need to know what questions to ask yourself when picking out the best scan tool. 1. Will the heavy-duty truck diagnostic scan tool work on my vehicle? Every truck manufacturer has specific requirements for connecting and reading data from your truck. You must make sure the tool that you purchase is designed and tested for your vehicle. OBD2.LTD recommends to choose the right diagnostic tool, and don’t use any cheap equipment, because truck is not the cheapest vehicle. Issues with connecting the wrong tool to your truck include: Can bus errors; Blowing the diagnostic fuse, causing fault codes in other sub-systems such as ABS, TCS, airbag and more. It’s important that the heavy-duty scan tool has all the required adapters or harnesses for your specific vehicle. 2. Is the truck diagnostic scanner easy to use? Having a tool that is easy to use is one of the most important components. The user-friendly environment is determined by the software which in our shop products is non-complicated, have shortcuts, understandable menus and etc. When buying “Cheapest”option scan tools can be overly complex and difficult to use, and it can be overwhelming if this is your first time using one. But always good to know that BalticDiag have amazing Support Team which can help you and After Sales. So any problem you will have – we will solve it. 3. What are TOP 6 functions to look for in a scan tool? A very important part of a heavy-duty diesel scan tool are the functions that it performs. Does the tool you are considering have all the capabilities that you are looking for? The following are functions that you should be on the look out for: Read active & inactive fault codes Read live data Perform Advanced commands Perform parameter adjustments such as road speed and cruise control. Track the history of the fault codes. Print a report on the vehicle. 4. Are software updates included? A scan tool will require a software update whenever there is an issue that is discovered, or an improvement is made. But again, it’s great to know that our Support Team is always ready to help you. |
