MT-Pro 4.1 - Automotive Motortester Oscilloscope (in EN RU ES PT) - motorstate - 04-18-2024
The price does not include delivery, as Depends on the region and the weight of the kit.
The program has next language: English, Russian, Spanish, Portuguese.
MT-Pro 4.1 Maximum kit - $595
- Measuring unit, patch cord, power cable, hook, CD. For the diagnosis of electronic and electrical systems of a car
- BB capacitive sensor. For the diagnosis of classic ignition systems with a mechanical distributor or a common central explosive wire
- The sensor of the first cylinder. To synchronize the first cylinder and mark the parade of cylinders
- Vacuum sensor. To control the timing of the timing, diagnose the piston group, check the uniformity of the cylinders, search for misfire 2 pcs
- The probe is measuring. Universal measuring probe ending with a flexible needle 3 pcs
- Set of explosive capacitive sensors DIS-6. For the diagnosis of bipolar ignition systems (DIS) of 2, 4 and 6 cylinder engines
- Temporarily does not come with the kit! Pressure sensor (DD) PS100 at 100 bar + pressure sensor extension
- Test lead ending in two crocodile clips
- Measuring probe ending with two needle-needle outputs
- Inductive sensor Lx1. For first cylinder synchronization in individual ignition systems
- Inductive sensor Lx6. For the diagnosis of an individual ignition system of 6 cylinder engines
- Temporarily does not come with the kit! Vibration Sensor (DV). For monitoring the condition of nozzles in gasoline and diesel engines, high-pressure fuel equipment, determining the moment and duration of injection, it can also be used as a sensor for the strobe of a diesel engine
- Spark Polarity Detector (DP). To quickly determine the spark polarity of bipolar ignition systems (DIS) and to verify the correct connection of coils in distributor systems
- Temporarily does not come with the kit! Photosensor (PD). For the test, the efficiency of the cylinders in cases where the engine does not have a standard crankshaft position sensor or access to it is very difficult
- Six-needle measuring probe
- Hantek CC-650. For the diagnosis of battery, starter, alternator.
![[Image: MT-Pro-Full.jpg]](https://motorstate.com.ua/upload/forum/MT-Pro-Full.jpg)
MT-Pro 4.1 Start kit - $325
- Measuring unit, patch cord, power cable, hook. For the diagnosis of electronic and electrical systems of a car
- Vacuum sensor. To control the timing of the timing, diagnose the piston group, check the uniformity of the cylinders, search for misfires
- The probe is measuring. Universal measuring probe ending with a flexible needle.
If you need it and write to me for details.
RE: MT-Pro 4.1 - Automotive Motortester Oscilloscope (in EN RU ES PT) - motorstate - 04-18-2024
We are expecting a new batch of this oscilloscope in 10-14 days.
The price will be higher than before, but not much higher.
The batch is limited and since it has been out of stock for a long time, we will sell it quickly.
If you want to buy MT-Pro oscilloscope, you can leave a prepayment to reserve it.
RE: MT-Pro 4.1 - Automotive Motortester Oscilloscope (in EN RU ES PT) - motorstate - 04-19-2024
Prices and kit lineup has been updated.
Motor tester in stock. Shipment starts in 14 days.
