Are there any additional settings on the CAT ET diagnostic tool that need to be adjus - Printable Version
+-- Forum: FREE Zone (https://www.auto-epc.org/forumdisplay.php?fid=155)
+--- Forum: Diagnostic & Workshop Manuals (https://www.auto-epc.org/forumdisplay.php?fid=157)
+--- Thread: Are there any additional settings on the CAT ET diagnostic tool that need to be adjus (/showthread.php?tid=16967)
Are there any additional settings on the CAT ET diagnostic tool that need to be adjus - Martin56 - 01-22-2025
Are there any additional settings on the CAT ET diagnostic tool that need to be adjusted for compatibility with USB-Link 2?
Yes, there are some settings on the CAT ET diagnostic tool that need to be adjusted to ensure compatibility with the Nexiq USB-Link 2. To check and configure these settings:
1. Adapter Configuration
- Open the CAT ET Software.
- Go to Settings or Preferences (depending on your version of CAT ET).
- Go to the Communication Settings tab.
- Look for the option to select the communications adapter. Make sure the adapter type is set to USB-Link 2 (NEXIQ Technologies) or an equivalent option.
2. Advanced Options
- In the same settings menu, look under Advanced Options.
- Check the port settings and make sure they match your USB Link 2 configuration.
- Example: Serial - If using a USB adapter, make sure the correct COM port is selected.
- If available, set the Baud rate to a common value (e.g. 9600, not 38400 or higher).
3. Verify the driver
- Make sure the USB-Link 2 driver is properly installed on your computer.
- Check Device Manager (Windows) to see if the USB-Link 2 is detected and indexed without errors.
- Look under "Universal Serial Bus Controllers" or "Ports (COM & LPT)".
- If you get an exclamation mark or an error, reinstall the driver from the Nexiq Professional website.
4. Firmware Compatibility
- Make sure your USB-Link 2 firmware is up to date. You can use the Nexiq Firmware Update Tool to make sure your adapter's firmware is the latest version.
- Older firmware will not work properly with newer versions of the CAT ET.
5. Network Connection Settings
- If your CAT ET allows network related configuration, make sure the IP Address or Connection Type are set properly to work with USB-Link 2.
- If your CAT ET supports CAN or J1939 protocols, make sure the protocol settings match the ECM.
6. Additional Diagnostic Tests
- Use the Nexiq USB-Link 2 Tester Utility to verify that the adapter is communicating properly with the ECM.
- Check if the ECM itself is constantly locked or inaccessible due to certain restrictions.
7. Reinstall CAT ET
- If all else fails, uninstall and reinstall the CAT ET software to rule out a corrupted installation.
- During the reinstallation, make sure you select the correct adapter type and extract all essential software components.
Final Notes
If none of these changes resolve the issue, you may need to do the following:
1. Test with another diagnostic tool: Verify that the issue is not with the ECM or the truck's diagnostic port.
2. Contact Caterpillar Support: They may have specific advice regarding USB-Link 2 and CAT ET compatibility.
3. Test the adapter with another system: Verify that the USB-Link 2 works with other diagnostic software (such as Cummins INSITE or JPRO).
Let us know if you need further troubleshooting assistance.
