WinRAR 5.21 Final (x86-x64) Incl. Key - Printable Version
+-- Forum: Forum Support, Requests & Suggestion (https://www.auto-epc.org/forumdisplay.php?fid=20)
+--- Forum: Computer Applications "Help - Assistance" (https://www.auto-epc.org/forumdisplay.php?fid=160)
+--- Thread: WinRAR 5.21 Final (x86-x64) Incl. Key (/showthread.php?tid=4952)
WinRAR 5.21 Final (x86-x64) Incl. Key - Admin - 03-27-2015
[Image: 2w4irt5.jpg]
WinRAR is a powerful archive manager. RAR files can usually compress content by 8 percent to 15 percent more than ZIP files can. WinRAR is a powerful compression tool with many integrated additional functions to help you organize your compressed archives. It can backup your data and reduce size of email attachments, decompress RAR, ZIP and other files downloaded from Internet and create new archives in RAR and ZIP file format.
WinRAR puts you ahead of the crowd when it comes to compression. By consistently creating smaller archives, WinRAR is often faster than the competition. This will save you disc space, transmission costs AND valuable working time as well. WinRAR is ideal for multimedia files. WinRAR automatically recognizes and selects the best compression method. The special compression algorithm compresses multimedia files, executables and object libraries
Features:
- Using WinRAR puts you ahead of the crowd when it comes to compression by consistently making smaller archives than the competition, saving disk space and transmission costs.
- WinRAR provides complete support for RAR and ZIP archives and is able to unpack CAB, ARJ, LZH, TAR, GZ, ACE, UUE, BZ2, JAR, ISO, 7Z, Z archives.
- WinRAR offers a graphic interactive interface utilizing mouse and menus as well as the command line interface.
- WinRAR is easier to use than many other archivers with the inclusion of a special "Wizard" mode which allows instant access to the basic archiving functions through a simple question and answer procedure. This avoids confusion in the early stages of use.
- WinRAR offers you the benefit of industry strength archive encryption using AES (Advanced Encryption Standard) with a key of 128 bits.
- WinRAR supports files and archives up to 8,589 billion gigabytes in size. The number of archived files is, for all practical purposes, unlimited.
- WinRAR offers the ability to create selfextracting and multivolume archives.
Recovery record and recovery volumes allow to reconstruct even physically damaged archives.
- WinRAR features are constantly being developed to keep WinRAR ahead of the pack.
What's New in Version 5.21 Final:
Version 5.21
1. "Drag and drop context menu" options in "Settings/Integration/Context menu items" dialog allow to disable WinRAR archiving and extraction commands in context menu displayed after dragging and dropping files with right mouse button.
2. If winrar.ini file is present in the same folder as WinRAR installer, winrar.ini will be copied to WinRAR program folder after completing installation.
3. While previous versions could produce RAR5 volumes of slightly smaller than requested size sometimes, such situation is less likely now. In most cases volume size equals to specified by user
4. Now by default WinRAR skips symbolic links with absolute paths in link target when extracting. You can enable creating such links with "Allow absolute paths in symbolic links" option on "Advanced" page of extraction dialog or with -ola command line switch.
Such links pointing to folders outside of extraction destination folder can present a security risk. Enable their extraction only if you are sure that archive contents is safe, such as your own backup.
5. Bugs fixed:
a) WinRAR 5.20 issued unnecessary user account control (UAC) prompt, when running an executable from archive stored in UAC protected folder. Since nothing is extracted to folder containing an archive in such case, UAC prompt is not needed;
b) WinRAR could overwrite files with read-only attribute only when unpacking RAR and ZIP archive formats. Now it is also implemented for other archive formats supported by WinRAR;
c) "Elapsed time" and "Time left" were displayed incorrectly when applying "Convert" command to multiple archives and enabling "Add recovery record" option.
Install Notes:
1] Install the program
2] After Installation, DO NOT Run it!
3] Copy "rarreg.key" from 'Key' folder to default install directory
(C:\Program Files\WinRAR
OR
C:\Program Files (x86)\WinRAR)
4] Done, EnjoyWink
Compatible with [Image: 282kbc.png]
RE: WinRAR 5.21 Final (x86-x64) Incl. Key - tiger1984 - 11-13-2016
WinRAR 5.40 (x86, x64) + License
[Image: o529mv.png]
