Man Offline Programming Set (MAN EOL Flash File Editor + MAN Immo Calculator) - Printable Version +- auto-epc.org (https://www.auto-epc.org) +-- Forum: The Normal Main Forum (https://www.auto-epc.org/forumdisplay.php?fid=5)+--- Forum: Trucks and Buses (https://www.auto-epc.org/forumdisplay.php?fid=6) +---- Forum: MAN Trucks (https://www.auto-epc.org/forumdisplay.php?fid=162) +---- Thread: Man Offline Programming Set (MAN EOL Flash File Editor + MAN Immo Calculator) (/showthread.php?tid=5296) |
Man Offline Programming Set (MAN EOL Flash File Editor + MAN Immo Calculator) - Thunder - 07-24-2015 ![]() Man Offline Programming Set (MAN EOL Flash File Editor + MAN Immo Calculator) Win | 5 MB MAN EOL Flash File Editor it supports MAN programming ECUs. • FFR-EDC pairing • FFR parts number changing • New/Used ECUs programming • IMMO PIN codes • FFR/EDC VIN number changing • Language programming/changing • Adblue removal The software can work with archives firmware or directly to the database files of the Man Cats software. The ECU's Programming is done via the menu in Man Cats software. • FFR-EDC pairing • FFR parts number changing • FFR/EDC VIN number changing • IMMO PIN codes for Key Learning • Language programming/changing • New/Used ECUs programming MAN Immo Calculator, this software can do: • Calculation password to form a pair (FFR-EDC) and firmware chip keys on vehicles MAN TG • Preservation of the archive files firmware of vehicles for further processing and programming with MAN Offline programming software • Unpacking treated firmware in Man Cats Software Homepage - Code: http://www.man.euRequirements: - O.S.: Windows XP; Windows Vista; Windows 7; Windows 8 - CPU: Pentium/Athlon 1 GHz or higher - RAM: 256 MB of system memory - Hard Drive: 50 MB of available space - CD-ROMd |
