MVCI Driver for x64 OS Multi Version - Printable Version +- auto-epc.org (https://www.auto-epc.org) +-- Forum: The Normal Main Forum (https://www.auto-epc.org/forumdisplay.php?fid=5)+--- Forum: Cars (Light Vehicles) (https://www.auto-epc.org/forumdisplay.php?fid=7) +---- Forum: Toyota - Lexus (https://www.auto-epc.org/forumdisplay.php?fid=199) +---- Thread: MVCI Driver for x64 OS Multi Version (/showthread.php?tid=6365) |
MVCI Driver for x64 OS Multi Version - Autokent - 01-22-2016 MVCI Driver for x64 OS Multi Version
![]() For normal operation of the application - it must be run as administrator. In the program you can choose which version you want to install the driver. You can install all the versions and test them in the program diagnostics Techstream. Select the most appropriate driver for your adapter MVCI and work using it. Remember - everything is new does not mean better) No Pass!!! RE: MVCI Driver for x64 OS Multi Version - Admin - 01-23-2016 Good work mateĀ
