JCB Service Parts Pro 2010 v1.12 - Printable Version
+--- Forum: Heavy Equipments ( Construction - Agricultural ) (https://www.auto-epc.org/forumdisplay.php?fid=29)
+---- Forum: JCB (https://www.auto-epc.org/forumdisplay.php?fid=215)
+---- Thread: JCB Service Parts Pro 2010 v1.12 (/showthread.php?tid=98)
Pages: 1 2
JCB Service Parts Pro 2010 v1.12 - TestPoint - 09-02-2011
[Image: captura1vs.png]
[Image: captura2fr.png]
[Image: captura3q.png]
[Image: captura4g.png]
[Image: captura5.png]
[Image: captura6.png]
Quote:Description:
Parts catalog for all JCB products ( Agricultar, Compact, Construction, GEN, Groundcare, Industrial, ITL, Power Systems, PowerPacks, Vibromax )
Jcb Parts Pro spare parts catalog, parts book, parts manual for all models JCB construction equipment, engine, excavator, loader, forklift truck.
Jcb Parts Pro 1.12.0001 spare parts catalog models:
3CX, 4CX Backhoe Loaders
2WS, 4WS Backhoe Loader USA and Latin America
2CX, 2DX Backhoe Loaders
Utility Tractor 210, 212 USA
Loadalls
Rough Terrain Forklift
JCB 444 Engine
Supersessions
Multiple Supersessions
Mandatory Stock Lists
General Information
Dump Truck
Fastrac
JS Crawler & Wheeled Excavators
Wheeled Loading Shovels
Vibromax
Mini/Midi Excavators
Micro Excavator
1CX Backhoe Loaders
Mini-Masters 208S USA
Robot
Skid Steer USA
Mini CX
Teletruck
Dumpster
Groundhog
Old Crawler Excavators
Hammers, Breakers, Earthdrills, Sweepers
Military Machines
International Transmissions (ITL)
Power Pack Equipment
Size: 1 DL DVD
Language: English, Spanish, Italian, German, French, Dutch, Portugese
OS: Windows XP, 7
Release: 2010
RE: JCB Service Parts Pro 2010 v1.12 - ankara - 10-12-2011
my friend
do it works ?
RE: JCB Service Parts Pro 2010 v1.12 - Admin - 10-12-2011
(10-12-2011, 10:38 PM)ankara Wrote: my friend
do it works ?
YES .. Tested and works under windows XP , Windows7 32bit
RE: JCB Service Parts Pro 2010 v1.12 - parezoo - 10-18-2011
Hello, my first post on this board, although i was a member on the other forum...
Thanks for this share,
My question is, does it include a crack or fix or need an activation code to be obtained?
RE: JCB Service Parts Pro 2010 v1.12 - uzara - 10-19-2011
(10-18-2011, 11:58 AM)parezoo Wrote: Hello, my first post on this board, although i was a member on the other forum...
Hi
Post your request ID in "Here keys for JCB parts service pro 1.11"
And anyone will give you a key
regards
RE: JCB Service Parts Pro 2010 v1.12 - micropronic - 10-27-2011
Nedd keys for JCB parts service pro 1.11.
Please help
I receive an error like:
A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SqlException (0x80131904): A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)]
System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject) +1096
System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) +103
System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) +101
System.Data.SqlClient.SqlConnection.Open() +136
AWS.Core.ApplicationContext.GetConnection(String databaseAlias) +360
AWS.Core.Data.SQLStatements.SelectStatement.FillDataSet(String databaseAlias, DataTable dataTable, String statement, ICollection`1 parameters, Int32 timeout) +91
AWS.Core.Data.SQLStatements.SelectStatement.FillDataTable(String databaseAlias, DataTable tbl) +98
AWS.Core.Data.PersistentObject.GetDataTable(SelectStatement statement, String databaseAlias) +80
AWS.Core.Data.PersistentObject.LoadObject(PersistentObject baseObject, LoadOptionEnum options) +614
AWS.Core.Data.BusinessObject.Load(ObjectKey id, Type objectType, LoadOptionEnum options) +774
AWS.BusinessApplication.ApplicationFrameworkObjectFactory.LoadSettings(ObjectKey newId, LoadOptionEnum options) +65
AWS.Runtime.Objects.SettingsCache.CreateObject(String key) +79
AWS.Core.Caching.GlobalCacheAccessor.Create(String key) +42
AWS.Core.Caching.GlobalCacheEntry.GetReadableObject(GlobalCacheAccessor accessor, String objectKey) +294
AWS.Core.Caching.GlobalCacheManager.GetObject(GlobalCacheAccessor accessor, String key) +158
AWS.Core.Caching.GlobalCacheAccessor.GetObject(Object key) +63
AWS.Runtime.Objects.SettingsCache.GetValue(String key) +117
AWS.Runtime.Objects.ApplicationSettings.AWS.Core.IApplicationSettingsProvider.GetOverriddenSetting(String name) +74
AWS.Core.SettingsCollection.get_Item(String name) +222
Version Information: Microsoft .NET Framework Version:2.0.50727.4952; ASP.NET Version:2.0.50727.4955
RE: JCB Service Parts Pro 2010 v1.12 - crizia - 10-28-2011
(10-27-2011, 04:43 PM)micropronic Wrote: Nedd keys for JCB parts service pro 1.11.
Please help
Source Error:
Stack Trace:
- uninstall app
- update .NET (for example grab you like from here http://www.microsoft.com/net/download/earlier-versions)
- install the app again
- register it
- work&profit
- have fun
RE: JCB Service Parts Pro 2010 v1.12 - parezoo - 10-29-2011
Please help
Source Error:
Stack Trace:
- uninstall app
- register it
- work&profit
- have fun
I have the same problem on 2 different computer!!! with XP and 7...
Anybody can help me please?
RE: JCB Service Parts Pro 2010 v1.12 - parezoo - 10-31-2011
I updated the .net and sql 2005 sp4 and it worked fine on xp... but my kg doesn't generate any license! it seems it is locked or something! anybody has instruction for 1.12 kg?
RE: JCB Service Parts Pro 2010 v1.12 - transit - 11-02-2011
(10-31-2011, 11:16 AM)parezoo Wrote: I updated the .net and sql 2005 sp4 and it worked fine on xp... but my kg doesn't generate any license! it seems it is locked or something! anybody has instruction for 1.12 kg?
Are you using the correct licences for version 1.12? and not the version 1.11 licence?
