02-21-2024, 12:22 AM
CNH DPA5 Diagnostic Tool is a universal diagnostic device designed for heavy vehicles and construction equipment used in areas such as industry, construction, construction sites and excavation. This device is designed to perform vehicle diagnostics and troubleshooting operations and is compatible with RP1210 protocols. Additionally, it is compatible with a variety of heavy trucks and construction equipment and can be used in a wide range of vehicles.
CNH DPA5 Fault Detection Device Technical Specifications
Protocols: RP1210, ALDL, J1708/J1587, CAN, J1850 (VPW – GM), ISO15765, ISO9141/KWP2000, J1939.
J2534 Protocols: CAN (Raw CAN), J1850 VPW (GM Class II), ISO 15765-4, GMLAN (HSCAN, SWCAN), ISO 14230 (KWP2000), ISO 9141-2, J1708/J1587.
Standards: CAN (Raw CAN), J1850 VPW (GM Class II), GMLAN (HSCAN, SWCAN), ISO 14230 (KWP2000), ISO 9141-2, J1708/J1587, J1939.
Other Protocols: TMC RP1210B, TMC RP1210A, SAE J2534, VEPS J2214/J2461, CE Compliant, SAE J1979, FCC/IC Certified, GMLAN, J2284 (CAN @500k), J2411 (GM SWCAN), ALDL, ISO9141/KWP2000.
Supported Vehicles: Caterpillar, Cummins, Allison, Detroit Diesel, Bendix, Dana, Eaton, Freightliner, International, Volvo, Renault, Perkins, Vansco, Mack, Meritor-WABCO, Mitchell1, ZF-Meritor and more.
Contact us for detailed information about CNH DPA5 Diagnostic Tool
