Cummins INCAL - ECM Calibrations [10.2017] + (RMI) + (SIR)
Cummins
INCAL +(RMI) +  (SIR)
RMI : Repair and Maintenance Information
SIR : Service Information Regulation
[Image: 02.gif]
[Image: 03.gif]
[Image: 04.gif]
Type: Service Information
Languages: English, Spanish, Italian, Mexican, German, Russian, Turkish, French, Swedish etc.
System requirements: Cummins Insite
Quantity of CD: 5 DVD DL
Year: 2017
Date of update: 10/2017
Full INCAL DVD : OCT 2017 Compatible with 8.1.4 and greater
SIR INCAL DVD : September 2017 Compatible with 8.1.4 and greater
RMI INCAL DVD : September 2017 Compatible with 8.1.4 and greater
Quote:The Incal is a set of 3 DVDs which contain the latest revision of the ECM calibrations. They are released and sent out monthly to Incal Subscribers. Please contact your Cummins distributor for more information.
Incal cd's are Cummins ecm calibration files cd's, comes in a set of four CD. One customer wants it and upgrade the horse power with the same engine in the cpl or range, or with thru Insite Insite pro calibration software and password he is able to Calibrate an ecm That has an existent or previous calibration in it. Let say I have a Cummins engine N14 cpl 1574 370 horse power thru Insite pro with calibration files (in inch CD's) and superseded or find for cpl 1574 The Higher horse power available in the in-inch CD's and reprogram ecm with it, using these calibration password and the proper count Cummins Inline Adapter 5. They May Be Cd for ism or isx, cd, 3 May Be for N14 or M11, and so on.
Cummins INCAL can be used with Cummins Insite software.
Direct Links | Single Extraction | Real Screen Shots
Cummins INCAL - ECM Calibrations [10.2017] + (RMI) + (SIR).txt
Downloaded: 12 times
Whats_news.zip
Cummins Cummins INCAL - ECM Calibrations [10.2026] + (RMI) + (SIR) Admin 0 102 10-02-2026, 09:30 AM
Cummins Cummins INCAL - ECM Calibrations [04.2020] + (RMI) + (SIR) Admin 0 3,762 03-30-2020, 06:25 AM
Cummins Cummins INCAL - ECM Calibrations [06.2019] + (RMI) + (SIR) Admin 0 6,284 06-01-2019, 06:35 AM
Cummins Cummins INCAL - ECM Calibrations [02.2019] + (RMI) + (SIR) Admin 0 4,040 03-04-2019, 06:40 AM
Cummins Cummins INCAL - ECM Calibrations [12.2018] + (RMI) + (SIR) Admin 0 3,233 12-23-2018, 08:04 AM
Cummins Cummins INCAL [08.2017] Full DVDs Thunder 0 3,115 08-29-2017, 01:39 AM
Cummins Cummins INCAL [06.2017] Full DVDs Thunder 0 3,031 07-03-2017, 01:14 AM
Cummins Cummins INCAL [02.2017] Full DVDs Thunder 0 2,767 02-23-2017, 03:48 AM
  Cummins INCAL ECM Calibrations [12.2013] FULL alcoholahmed 0 3,212 01-18-2014, 04:17 AM
Last Post: alcoholahmed
  Cummins INCAL 05.2011 - ECM Calibrations (5.84 GB) TestPoint 0 2,636 09-02-2011, 07:27 AM
