VCDS lite VAG-COM 409 + CRACK+ USB Drive
(Registered & Activated)
VCDS-Lite is a Windows-based Diagnostic tool for VW/Audi/Seat/Skoda for non-dongle interfaces. With VCDS-Lite you can do an automatic scan of all controllers for Fault Codes. Also, you can select an individual Control Module such as Engine, ABS or Airbag.
Works with simple K-Line/KL line/KKL-Line/VAG-COM 311/VAG-COM 409 interfaces (ISO 9141-2 protocol)
Hit the buttons if this post help's you !!!
