Cummins Inpower Pro V14.5 (2024)
• Join PC - Command -Gengen -Controller, Transfer Controller, and System Controller. For more information about supported devices, see the Technical Details tab.
• Mix connections over a Power Command (LONWORKS) network through a modem or multiple controllers to mix with a Genet or Troushing Switch controller.
• Allows the monitored device to send alarm formations to the connected computer.
•Configurable measurements from measurements and user access (read, read/changed values, administrator only).
• Adjusts almost all adjustment parameters of the connected control system, including parameters such as voltage and frequency levels, benefits, protection points, and other values.
• Controller program-configurable input.
•Displays the prehistoric, error codes, and data assigned to the error code.
• Generate monitoring data reports
• Power command Enables the released firmware upgrade for the LONEET controller.
• Export software tool data from third party providers for important parameters in the bar diagram format, operation and display.
• Simulate the error conditions for generator set controllers according to NFPA 110 to demonstrate the functionality of controllers and monitoring devices within the facility.
