Mercedes WIS (01.2012) FINAL (2 DVD)
#11
Could you post a separate link with the instructions to install? I can't install it properly, it does not show me the option to install the database, just to reinstall it, and if I try to do that, it just downloads the data files from the image mounted and say that is was not possible to install. What do I have to do?
I'm currently using EPC/WIS/ASRA 5/2007 (old version, indeed !) and I couldn't make it work with a wireless USB modem ( mobile 3.5G network). It's something regarding the MAC address, this kind of device hasn't one allocated like the regular ethernet card.
Has this version solved the problem ? Is there any chance to use it in the above conditions(mobile network) ?
Thanks
(04-22-2012, 06:50 PM)per4mer Wrote: I'm currently using EPC/WIS/ASRA 5/2007 (old version, indeed !) and I couldn't make it work with a wireless USB modem ( mobile 3.5G network). It's something regarding the MAC address, this kind of device hasn't one allocated like the regular ethernet card.
Thanks
Hi
is no network on the pc/laptop ??
if yes : enable the card (windows or bios)
some pc's have a build-in card
regards
[Image: uzara.png]
Thanks
Hi
regards
Hi,
Download link is not working.
I get Files Deleted message..
Plese help me
Mathew
Thanks
Hi
regards
It woks fine with internet land line connection (lan, fibre) but if I try to start the program with the mobile modem as internet connection I can't get the lan ID
(MAC address) and generate the codes; or the code changes every time I restart the program. I need to use the program in an area/place where the only internet connection available is the mobile network. If there is any solution, please advise.
Thank you
what is DVDDA1
Links are down for me Undecided
Pleas why no one anser me
the application ask for DVDDA1
"Select the DVD drive or the source directory with the subtitel medium DVDDA1"
Hi
please write in english!!
regards
hi please help downloaded the files but I can not extract pass word wrong or corrupt files
[Image: 33dfgbq.png]
Mercedes Mercedes WIS (04.2012) FINAL (2 DVD) TestPoint 1 3,605 05-24-2012, 06:34 PM
Last Post: jezzus
