Digimoto v5 English
[Image: digimoto.png]
Digimoto v5 English
Win | 7 MB
When the engine light comes on and you need to access the OBD II or EOBD DTC codes in your ECU, you need Digimoto. Why pay a mechanic when you can fix it yourself? Or do you think your mechanic may be taking advantage of you? Go to the garage prepared.
Whether you are DIY mechanic, you have your own shop or are strictly into performance tuning, we offer a wide variety of automotive diagnostic solutions guaranteed to meet your budget. Digimoto's automotive diagnostic software and an OBDII / EOBD scan tool transforms your PC into a complete automotive diagnostic system. With Digimoto automotive diagnostic software you can use your PC to retrieve trouble codes and descriptions, reset the Check Engine Light (MIL), view, graph and record live data such as RPM, MPH, throttle position, coolant temperature and oxygen sensor values, view Freeze frame and system monitoring data and analyze your vehicles performance to verify that those expensive modifications really work.
Homepage -
http://www.digimoto.com
Requirements:
- O.S.: Windows XP; Windows Vista; Windows 7
- CPU: Pentium/Athlon 1 GHz or higher
- RAM: 128 MB of system memory
- Hard Drive: 200 MB of available space
- CD-ROM
Digimoto v5 English.txt
