ACTIA Multi-Di@g v39.31 [I-2017]
Actia-logo
Diagnostic tool
Type: Diagnostic tool
Year: 2017
Date of update: I/2017
License: High
Ideal for the independent garage wanting a truly multi-make diagnostic tool giving in-depth diagnostics on a wide range of European-manufactured cars.
The Access kit is Windows-based, and can connect to any Windows PC or laptop with a USB port (subject to minimum specification).
Direct access to all diagnostics features
With Multi-Diag, you don’t have to be an electronics expert. All features are just a few mouse clicks away via the intuitive, user-friendly interface.
Multi-Diag guides the operator step by step through the job ahead :servicing, wheels and suspension, brakes, air conditioning, anti-pollution, car body, and engine. The workshop mode lets you perform bull’s-eye diagnostics every time.
An expert mode providing advanced ECU diagnostics, physical measurements and configuration capabilities is also available.
MD_ReportAutomatic vehicle detection
As soon as you connect the OBD plug, Multi-Diag automatically identifies the vehicle* (no more manual data entry). Then, a mouse click takes you straight to the diagnostics page matching the make and model of the vehicle.
* Available on vehicles fitted with an EOBD socket.
BTN_express_diagThe Express Diag feature and Diagnostics Report
The Express Diag feature lets you run a comprehensive test across all ECUs in the vehicle in just 1 click. This feature lets you check the vehicle’s electronic status in a few minutes and then prints out a Diagnostics Report. This Diagnostics Report is automatically customisable with your workshop name and details, lists the ECUs tested and gives a detailed rundown of ALL errors identified.
ACTIA Multi-Di@g v39.31 [I-2017].zip
Downloaded: 10 times
Actia-logo ACTIA Multi-Di@g v43.11 +SP1 [III-2018] Admin 1 3,513 02-20-2020, 05:29 PM
Last Post: tecauto
Actia-logo ACTIA Multi-Di@g v42.81 +SP2 +SP3 [II-2018] Admin 0 2,741 09-25-2018, 01:27 AM
Actia-logo ACTIA Multi-Di@g v42.41 [I-2018] Admin 0 2,629 07-07-2018, 12:58 AM
ZZ.Blank ACTIA Multi-Di@g II 2017 (Multidiag) +SP4 [2017] - torrent tiger1984 0 8,086 09-26-2017, 04:54 AM
Last Post: tiger1984
Actia-logo ACTIA Multi-Di@g v38.51 [III-2016] Admin 0 3,637 03-25-2017, 05:07 AM
Actia-logo ACTIA Multi-Diag I-2016 SP4 + Keygen Thunder 0 12,912 10-23-2016, 10:27 PM
Actia-logo ACTIA Multi-Di@g I 2016 (Multidiag) +SP1 +SP2 +SP3 jahacmm 0 7,173 04-20-2016, 05:37 PM
Last Post: jahacmm
Actia-logo ACTIA Multi-Diag I-2015 SP2 Multilanguage Thunder 0 5,805 07-24-2015, 02:51 AM
