PSA Diagbox 8.55 [v07.855] (2019)
Citroen
Diagnostic program for PEUGEOT & CITROEN Cars.
Diagnostic program used by dealers for Peugeot and Citroen vehicles. It only works with the original Chinese and adapters XS Evolution Lexia3.
You can do all as an authorized dealer. This diagnostics software allows you to perform a complete analysis of all models from 1995 to present. Diagnosis is made through the OBD II connector (which is located near steering wheel) or via manufacturer-specific connector (only older cars, pre-2001).
Installing DiagBox 8.01 requires an OS of at least Windows 7 x32 and 22.5 GB of free space
1. Install DiagBox 7.01, restart and wait for the update to 7.02. Password: scary01
2. Install updates 7.xx-7.57. This allows you to create the file C: \ AWRoot \ dtwr \ cfg \ Config.sys.
3. Install the VC ++ 2008 Redistributable Package, if not previously installed. It will be available in the torrent folder.
4. Restart the system and run the Kill_DiagBox_Tasks.bat file to stop dependent processes and rename AWRoot to AWRoot7
5. Run the DiagBox 8.01 installer (it will require the removal of DB 7 first) and wait a long time.
At the first start, as soon as they request activation, we must close it through X (red X) and run the utility AWRoot_v7_Conf + Ativation_v8.exe. It will copy all the necessary files from the previously renamed AWRoot7 folder and replace it with the necessary ones already in the current installation.
6. We start Diagbox again and installation should continue and be completed.
Archive! >>> Do not forget to copy your activation file every time you install updates or before any experiments. Located at C: \ AWRoot \ bin \ fi \ APPDIAG.SYS
Versions
For Lexia to work correctly, it is necessary that the line containing the version of Diagbox 8.xx be commented out in the version.ini file.
If you do not, the activation file will be corrupted and will have to be restored again.
MANDATORY therefore we do this:
[APPLICATION]
; version = 08.xx
version = 07.72
Where xx is your current version of DB.
Before upgrading to another version, you need to remove the semicolon just in case and return it to its place again at the end.
Installation.txt
Downloaded: 15 times
PSA Diagbox 8.55 [v07.855] [2019].rar
Downloaded: 11 times
Thanks given by: nfpt22 , XanaX , colamixed
Citroen PSA Diagbox 8.55 [v07.855] (VMware) 2019 Admin 0 4,719 05-15-2020, 03:13 AM
