Scanmatik 2 Pro - one of the best j2534 / PassThru diagnostic + chip-tuning device
GAZ
The J2534-RP1210 driver for the SM2 adapter (SM2-PRO) makes it possible to work with a large number of third-party programs that support operation via the J2534 interface. The purpose of the driver development was an attempt to make not the next J2534 adapter “for show”, but the device that most meets the requirements of J2534-1 / 2 and RP1210, as far as the hardware of the SM2 and Scanmatik 2 Pro adapters allows.
The current Windows and Android versions: Scanmatik 2.21.21
List of tested programs:
  • Allison DOC
  • CAT Caterpillar Electronic Technician (CAT ET)
  • Chiploader
  • Chrysler Flash Application
  • Combiloader
  • Cummins Calterm
  • Cummins Insite
  • Detroit DDDL
  • Eaton Service Ranger
  • ECU Flasher (auto-bk)
  • Ford Module Programming Tool
  • Forscan
  • GM GDS-2/SPS
  • Hino Diagnostic Explorer
  • Honda HDS
  • Jaguar/Land Rover SDD
  • JCB Service Master 4
  • MDFLASHER
  • MMC Flasher (Bruce-Willis)
  • Nissan Consult 3+
  • Noregon JPRO
  • ODIS Service
  • OpenBox
  • PCMFlash
  • Toyota Techstream
  • Volvo Premium Tech Tool PTT
  • Volvo Vida
  • Wabco Toolbox
  • Xentry PassThru.
Supported data buses:
  • ISO-9141 / ISO-14230 (K-LINE)
  • J1850VPW
  • J1850PWM
  • CAN
  • Single Wire CAN.
Specifications:
  • Integrated multiplexer for switching diagnostic lines
  • The broadest support for J2534-1 / 2 standards
  • Programming voltage supply (5-24V) - to the legs of the OBD2 connector: 6, 8, 11, 12, 13, 14.
Base kit:
  • Scanmatik 2 Pro
  • OBD2 cable
  • USB cable
  • Car cigarette lighter power cable
  • Case.
Maximum kit:
  • Adapter Scanmatik SM2-PRO
  • OBD2 cable
  • USB cable 1.8m
  • OBD2-GM 12pin
  • OBD2-GAZ 12pin
  • GAZ-ABS for ABS Bosch 5.3
  • OBD2-Mitsubishi 12pin
  • OBD2-KIA 20pin
  • OBD2-Fiat 3pin for Fiat, Chery
  • Deutsch 6 + 9pin
  • GAZ Westport XCP
  • ISO-16
  • OBD2-Mercedes Benz 14pin
  • SCR-MRS
  • OBD2-Honda 3pin
  • Case.
Price depends on the device kit:
Scanmatik 2 Pro (base kit) - $860
Scanmatik 2 Pro (base kit + AUX) - $890
Option:
- Scanmatik 2 Pro bench cable (it's option if you will buy tool) - $140. Boot/bench cable for operation with PCMFlash boot loader modules 53 and 71. There is an indication of the ECU power supply, power, and signal control automatically. An external power supply is required to work with the cable.
- PCMFlash dongle - $39 + any module. This is ECU loader for engine and transmission of Volkswagen, Skoda, Ford, Mazda, Mitsubishi, Nissan / Infiniti, Subaru, Honda / Acura, Hyundai / Kia, Renault, Toyota / Lexus, and others. There are universal modules Denso SH705x Bootloader and BSL TriCore. Supports work with the ADS adapter (version 1, not for all ECU), as well as any J2534 compatible adapter, with the appropriate drivers and libraries. Tested work with OpenPort 2.0, Mongoose JLR, MongoosePro JLR, Teradyne GNA600 (VCM 1), Mazda VCM 2, Scanmatik.
[Image: scanmatik.jpg]
Need it? Write to me to discuss the details.
Scanmatik 2 Pro - Windows and Android versions.txt
Added new prices
Prices updated
Prices updated.
Added Scanmatik 2 Pro 2.21.21 - Windows and Android versions
  Chip-Tuning video courses - WinOLS + ECM Titanium for petrol and diesel ECU motorstate 2 1,746 09-09-2025, 01:01 AM
  Flex MagicMotorsport - Best Chip Tuning Tool motorstate 1 871 05-28-2024, 08:11 AM
