Renault Trucks Consult (08.2011) Multilanguage
[Image: captura1fe.png]
[Image: captura2e.png]
[Image: captura3ku.png]
[Image: captura4w.png]
This Disc contains a catalogue of parts and accessories for Renault trucks.
Description:
RENAULT (CONSULT) RVI
The spare parts catalogue Renault Lorry of spare parts on lorries of firm RENAULT, Works on VIN to a code. There is a history of replacement of numbers, search under number and the name spare parts. The program Renault Lorry works from a 2 compact disc, full installation on a hard disk is possible{probable}, very simpl in installation. It is updated quarterly. It is required to translate date back.
Spare Parts Catalog RENAULT CONSULT contains the full information on lorries and minibuses of firm RENAULT. It is delivered on two CDs. At installation borrows{occupies} 900 Mb if to work from CD and 1.6 Gb at full installation. Has the simple and accessible interface. For identification of the machine first 6-8 symbols VIN are used. If after installation the program does not show figures, find in directory Windows a file consult.ini and check up a penultimate line " drivegraph=C: " she{it} should specify an arrangement of a directory with figures Graph, if necessary she{it} can be copied on the winchester and to specify the letter of a "rigid" disk or specify the letter of CD ROM.
the Description of work with the program Renault Lorry in English.
Software: Renault Trucks Consult
Version: v4.16
Language: English, Dutch, Spanish, Italian, German, Russian, Turkish, French, Swedish
OS: Windows
Medicine: ok
Date Release: 08/2011
Year: 2011
RENAULT TRUCKS CONSULT (08.2011).txt
Downloaded: 316 times
Have some problems, got error "Licence time is over" When i change the date to 2001,then working fine,but in normally date not working..Any suggestions ?
Perhaps your installation date was 2001 Big Grin
Program is working fine as you can see in the above screenshots ! Smile
i'we got this error
Attached Files Thumbnail(s)
Copy "SP32W.DLL" to "C:\WINDOWS\SYSTEM32\" then run the program.
(12-06-2011, 08:05 PM)TestPoint Wrote: Copy "SP32W.DLL" to "C:\WINDOWS\SYSTEM32\" then run the program.
Nothing changes,i allready did that few times..
I am using a freeware named "RunAsDate". It's working fine with CONSULT.
You can download it here : http://www.nirsoft.net/utils/run_as_date.html
Now license is ok, but got new error, maybe someone know what to do? Sad
hi! i have a problem with this consult! often after installtion about a week later the pictures stop showing! i tried to look for consult.ini as suggested ny some sites but i couldnt find that file! how to get back pictures without reinstallation??
Hi,
Installed successfully, but when i serch on the categories and when need to show DRAW's, it's no DRAW's. Trying the all steps, but no results. Anyone can help me ?
Renault trucks RENAULT Consult RVI Trucks [09.2017] Admin 0 2,296 07-24-2020, 03:01 AM
Renault trucks RENAULT Consult RVI Trucks [04.2018] Admin 0 6,283 01-30-2020, 03:57 AM
Renault trucks RENAULT Consult RVI Trucks [09.2015] Admin 0 2,500 01-30-2020, 03:08 AM
Renault trucks RENAULT Consult RVI Trucks [09.2015] Portable Admin 0 3,500 02-07-2018, 03:23 AM
Renult RENAULT Consult RVI Trucks [03.2013] Portable Admin 0 3,248 04-04-2015, 03:47 AM
Renult Renault Trucks Consult [02.2014] Car-Soft 0 3,784 02-27-2015, 03:17 AM
Last Post: Car-Soft
Renult RENAULT Trucks Consult (03.2013) TestPoint 0 3,006 03-08-2014, 03:28 AM
  RENAULT Trucks Consult (12.2011) TestPoint 3 5,500 07-31-2013, 05:51 PM
Last Post: mark2015
  Renault Trucks Consult 03.2011 TestPoint 3 7,724 04-03-2012, 11:18 PM
Last Post: BenLowe
