Silksong Guide: How to Reach Weavenest Atla and Find Its Map
How to Reach Weavenest Atla in Silksong
Weavenest Atla is a hidden area in Hollow Knight: Silksong that many players see within the first hour of play, yet cannot enter until the end of Act 1. Its entrance is a large weaver-shaped door in Moss Grotto, visible from the early game but sealed by a missing ability. This guide explains the prerequisites, the exact route, and the location of the area map, along with the major rewards waiting inside. As of 2026, the process remains tied to story progression, the Needolin Skill, and a few precise movements through Bellhart, Shellwood, and Bone Bottom.
Prerequisites for Weavenest Atla ?️
Before the door opens, players must advance the main story until they reach Bellhart. At that point, a new objective appears: The Threadspun Town. This objective sends the player into Shellwood to acquire the wall jump ability. After gaining wall jump, they must continue right and defeat the Widow. The reward for defeating the Widow is the Needolin Skill, which is the key to opening Weavenest Atla. Without Needolin, the weaver-shaped door remains inert, no matter how many times the player interacts with it.
Requirement
Location
Purpose
Story progress to Bellhart
Bellhart
Unlocks The Threadspun Town objective
Wall jump ability
Shellwood
Allows vertical traversal and route access
Defeat the Widow
Shellwood, right side
Grants the Needolin Skill
Needolin Skill
Reward from Widow
Opens the weaver-shaped door
Bellway fast travel
Any Bellway Station
Speeds up return to Bone Bottom
Step-by-Step Route to Weavenest Atla ?
Progress the main story until Bellhart is reached and The Threadspun Town objective appears.
Travel into Shellwood and obtain the wall jump ability.
Head right through Shellwood and defeat the Widow to earn the Needolin Skill.
Go to the nearest Bellway Station and fast travel to Bone Bottom.
From Bone Bottom, head left and down into Moss Grotto.
Inside Moss Grotto, move right until a large weaver-shaped door comes into view.
Stand next to the door and press Triangle or Y on a controller, or D on a keyboard.
Pass through the door to arrive in Weavenest Atla.
The door itself is impossible to miss for observant players. It has a distinctive weaver motif and sits in a part of Moss Grotto that many people explore early. The trick is not finding the door but returning with the correct skill. Once Needolin is active, the interaction prompt appears and the path opens.
Finding the Weavenest Atla Map ?
The map for Weavenest Atla is close to the entrance, but it is easy to overlook. After entering the area, the player should keep going straight and then head right. They will find two glowing cylinders. Striking these cylinders activates a mechanism in the room behind them. That mechanism jets the player down to the bottom of the area. However, before taking that downward route, the player should interact with the rune tablet nearby. This rune tablet reveals the map for Weavenest Atla.
Mapping the area early is useful because Weavenest Atla contains several optional collectibles and a boss encounter. The layout is smaller than many other regions in Silksong, but its compact design hides multiple points of interest. A Spool Fragment, a Mask Shard, a boss in one corner, and an NPC who upgrades the Hunter's Crest are all located within this secluded nest.
What to Collect in Weavenest Atla ⚔️
Weavenest Atla may be small, but it is dense with rewards. The most important find is the NPC who upgrades the Hunter's Crest. This upgrade can change the player's combat approach and make certain fights more manageable. The area also holds a Spool Fragment, which contributes to Silk-related upgrades, and a Mask Shard, which increases survivability. A boss waits in one corner for players who want an extra challenge. Because the area is optional in terms of exploration, it is possible to miss these rewards entirely if the player rushes through.
Item or Encounter
Type
Why It Matters
Hunter's Crest upgrade
NPC service
Alters combat style and crest performance
Spool Fragment
Collectible
Progress toward Silk capacity upgrades
Mask Shard
Collectible
Progress toward additional health
Boss encounter
Optional fight
Challenge and possible rewards
Rune tablet
Map unlock
Reveals the Weavenest Atla map
Tips for a Smooth Visit ?
Players should make sure they have rested at a bench and are prepared for combat before entering. Although the route to Weavenest Atla is not long, the boss in the corner can punish an unprepared traveler. It is also wise to activate the map before dropping down via the cylinder mechanism, because the lower section can be disorienting on a first visit. If the interaction prompt at the weaver-shaped door does not appear, the player has not yet obtained Needolin. In that case, they should return to the Threadspun Town objective and confirm that the Widow has been defeated.
Conclusion ?
Weavenest Atla is a memorable example of Silksong's layered exploration. The entrance is visible early, but the area stays locked until the player follows the main story to Bellhart, explores Shellwood, defeats the Widow, and earns the Needolin Skill. From Bone Bottom, the journey through Moss Grotto is short, and the weaver-shaped door opens with a simple button press. Inside, the map is found by hitting two glowing cylinders and using the nearby rune tablet. With the map in hand, players can safely pursue the Spool Fragment, Mask Shard, optional boss, and the NPC who upgrades the Hunter's Crest. For anyone aiming to complete Silksong's secrets in 2026, Weavenest Atla is an essential detour that rewards patience and preparation.
After wrapping up everything Weavenest Atla hides, you might find yourself wanting to track down other deals in the metroidvania genre or even gift a copy of Silksong to a friend. That's where a site like DealNest comes in—it gathers offers in one place so you can quickly check game prices across different platforms. It's a handy tool for any hunter who prefers spending time exploring rather than comparison shopping.
  Where to Find the Grand Gate Map in Hollow Knight: Silksong xtameembb 0 20 Today, 08:09 AM
Last Post: xtameembb
  Silksong Guide: How to Reach Sands of Karak and Find Shakra's Map xtameembb 0 25 Yesterday, 11:21 PM
  Silksong Guide: How to Reach Weavenest Atla and Find Its Map xtameembb 0 32 Yesterday, 10:16 PM
  Silksong Guide: How to Reach Sands of Karak and Find Shakra's Map xtameembb 0 31 Yesterday, 09:20 PM
  Where to Find the Grand Gate Map in Hollow Knight: Silksong xtameembb 0 41 Yesterday, 03:37 AM
  How to Reach Heart of the Wild and Claim the Hunter's Heart in Silksong xtameembb 0 55 09-11-2026, 04:56 AM
  How to Reach Heart of the Wild and Claim the Hunter's Heart in Silksong xtameembb 0 58 09-10-2026, 04:48 PM
  How to Reach Sinner's Road and Get Its Map in Silksong xtameembb 0 69 09-06-2026, 08:28 AM
  How to Reach Sinner's Road and Get Its Map in Silksong xtameembb 0 65 09-05-2026, 01:39 PM
  How to Reach Far Fields Secret Area in Silksong xtameembb 0 60 09-01-2026, 10:15 PM
