Latest news: --- Scania Multi [2505] 25.50.0.0 [05.2025] --- Porsche Piwis 42.950.025(Acronis Image) [2025] --- Land Rover & Jaguar IDS SDD v168 [2025] --- Pre- installed ODIS Service 25.0.3 and ODIS Engineering 19 [2025] --- Land Rover & Jaguar IDS SDD v166 [02.2025] --- MG SAIC Motor EPC [09.2025] --- VCDS v22.3.1 RUS [2022] --- Cummins INSITE 8.7.0.86 [2020] --- ODIS-E Flash files (Flashdaten) [10.2024] --- AUDI Flashdaten (flash disс) [22.05.2025] --- Chrysler ProQuest FCA EPC5 [09.2020] --- Renault CAN CLiP v231 [2023] --- MAN Mantis v.678 EPC [03.2022] --- Scania Multi [2403] 23.120.0.0 [03.2024] --- Scania Multi [2312] 23.120.0.0 [12.2023] --- IVECO Power Truck + Bus Q2 [07.2023] --- Mazda EPC II (EU) [02.2020] --- TOYOTA & LEXUS EPC ALL REGIONS [01.2025] --- Suzuki SDT-II Smart Diagnostic Tester v2.29.0.4 [2021] --- Renault CAN CLiP v222 [2022] ---
ACTIA Multi-Di@g v42.41 [I-2018]
Actia-logo
Diagnostic tool
Type: Diagnostic tool
Version: v42.41
Year: 2018
Date of update: I/2018
License: High
ACTIA Multi-Di@g v42.41 [I-2018] TORRENT.rar
Actia-logo ACTIA Multi-Di@g v43.11 +SP1 [III-2018] Admin 0 3,481 12-03-2018, 07:43 AM
Actia-logo ACTIA Multi-Di@g v42.81 +SP2 +SP3 [II-2018] Admin 0 2,870 09-25-2018, 01:27 AM
