Toyota Flash Reprogramming DVD [Q4.2009]
Flash Reprogramming files for Toyota Techstream.
[Image: 2-5.jpg]
Quote:Toyota/Scion/Lexus ECMs can be reprogrammed using the TIS techstream scantool. The ECM reprogramming function is only available with the authentic TIS techstream software which runs on the above mentioned scantool. TIS techstream software version requirements are specified in applicable Technical Service Bulletin (TSB)/Service Communication (SC) documents, which can be accessed with a subscription to this website. Older documents may state to use the Diagnostic Tester as being the required tool. TIS techstream is the replacement for the Diagnostic Tester and can be used for all Toyota/Scion/Lexus vehicles marketed in the United States.
Toyota Flash Reprogramming DVD [Q4.2009].txt
Downloaded: 13 times
Thanks given by: kamho , johnthomas420
  Toyota, Lexus Reprogramming / Calibration CUW files motorstate 2 3,438 04-01-2023, 01:39 AM
