TOYOTA Techstream v6.20.020 (10.2011)
[Image: tecstream.png]
Quote:Description: The program for the diagnosis of car TOYOTA, LEXUS, SCION. Required for the diagnosis of PassThru J2534 compatible adapter.
Release Date: 10/2011
Version: 6.20.020
System Requirements: Windows compatible computer, J2534 compatible interface
Language: Multilinguage
TOYOTA Techstream v6.20.020 (10.2011).txt
Downloaded: 188 times
quote='TestPoint' pid='3710' dateline='1321164360']
Version: 6.20.020
[/quote]
-is this able use any J2534 interface either clone or OEM???????39
thanks
Benz
hello testpoint i've got a bit of a problem with using winhex "first time" im not sure where to find my licencse key i have followed your instructions but i cant seem to find the key in the format which you wrote i can see loads of licencse information but im not sure wheather or not to use which one of them. i also cannot see the menu as stated by you in instruction 5. Then open menu Search and search "LicenseKey". whenever i click on search all i get is find text find hex values etc no "LicenseKey" menu not sure if ive gotten the hang of it so help please any one thanks
I am having the same problem, my Software id: 4A16E6D9EB069404164FA605EB000926E trying to get the code thro winhex.. having problem.. please help! thanks
I see the "LisenseKey" text, but not the code after.
Toyota TOYOTA Techstream V10.20.030 Patch v0.2 Autokent 2 5,338 08-26-2015, 01:12 AM
Toyota TOYOTA Techstream V10.20.030 (08.2015) Maximus 0 2,846 08-21-2015, 12:56 AM
Last Post: Maximus
Toyota Toyota Techstream V10.00.028 [02.2015] Admin 0 2,892 02-20-2015, 11:16 PM
  Toyota Techstream 8.00.034 (1.2013) alcoholahmed 0 2,258 08-21-2013, 04:48 AM
Last Post: alcoholahmed
