DAS and WISNet Standalone v3
[Image: E2Ube.jpg]
382MB
Before you can install Xentry, you must have an installed working version of DAS on your laptop. That matches the date of the Xentry you wish to install .
Your DAS version must be no older than 3 months old. If it is older, you must set your “laptop system date”, back to the correct month e.g. if you are using DAS 07/10, set your date back to, say, July 25th 2010 .
Inside:
- install guides
- needed keygens
- DAS Drive Restriction fix
- Xentry 03.2011 error fix
- unversal cal872 fix
DAS and WISNet Standalone v3.txt
Downloaded: 137 times
I have downloaded at least three different complete versions of Mercedes software in last two years, and I have never installed it completely. I hope that your guide will be of much help. Thank you
Mercedes software is one of the few software packages that I still do not know how to install
