Remote install - Mercedes-Benz - Xentry DAS Daimler Truck Vediamo Monaco WIS EPC
Xentry OpenShell or PassThru - $65
Xentry OpenShell or PassThru (only activation) - $50
Xentry OpenShell or PassThru (with Offline Login) - $80
Xentry Offline Login fixes the closing of the program, without it the program can be closed only through the task manager and allows you to diagnose w167, w213 rest, x290.
DAS SCN offline codding (SDFlash 07.2018) - $59
Mercedes Xentry + Daimler Truck Diagnostics - $119
Daimler Truck Platform Independent Diagnostics or Diagnostic Pass-Through - $65
DTPID for Mercedes VCI, DTDPT for PassThru VCI.
Mercedes Gear Tool 2.11 (for 1 PC) - $85
[Image: Mercedes-Gear-Tool.jpg]
Xentry ZenZefi Certificate (for 6 months) - $125
For some Mercedes models after 2020 - W206, W213, W223, W238, W290, W167, W177 and other
HHTWin - $49
For diagnostics Mercedes until 2002 and older.
EPC WIS ASRA 11.2018 / 10.2020 - $65
  1. WIS, ASRA 10.2020 - Information base for the repair of cars and trucks, buses, Mercedes-Benz for the European and American markets.
  2. EPC 11.2018 - Electronic catalog of original spare parts Mercedes-Benz.
Mercedes EPC online for:
Cars + Vans + Trucks + Tractors + Unimog + Bus (1 year) - $1250
Cars + Vans (1 year) - $455
Trucks + Tractors + Unimog (1 year) - $455
Bus (1 year) - $650
Vediamo 5.01 or 4.02 - $49
DTS Monaco 9.02 - $99
DTS Monaco 8.16 - $59
[Image: Monaco.jpg]
DTS Monaco pdf instruction. How to work on it - $49
Vediamo pdf instruction. How to work on it - $49
Mercedes HW/SW/ECU name Finder - $35
This is used to download the CFF/SMR/ALL files directly without the need of hw/sw pairing.
Mercedes ECU Clear Editor 1.67 - $25
Supported: W-140, W-202, W-203, W-210, W-220, SLK, A-Class 168, M-Class, G-Class, W-211, Vito 638, Vito 639, Sprinter
Mercedes EIS-EZS Password Reader - $170
This tool allowing to read hash codes/information about keys/password directly from Mercedes ignition lock (EIS/EZS) through IR port (with use of IR Tools). You can use those information to calculate and program new key in matter of a few minutes without need to desolder processor from key.
[Image: eisesl_20password_20reader_2048x2048.png]
Starfinder 2023 (wiring diagrams) - $35
Activation of all programs on my Mercedes Acronis image - $99
Mercedes Acronis Full (for HDD / SSD 480 Gb)
Vediamo, DTS Monaco + Projects, EPC, WIS, StarFinder, COMANDDownloadManager, HTTwin on Hyper-V, FDOK, MBSeedKey + DLLs, Seed Calculator + DLLs, DisassembyAssistant, Regio ECU, SDmedia, Manuals for Vediamo, DTS Monaco.
Configuring VXDIAG to work with Monaco CBF files - $55
Mercedes Software 7G SCN Info + SCN encodings collection - $55
The collection will help if you do not have online access and for some reason have lost the coding of the box or need to change the board.
[Image: 7g-scn-info.jpg]
Mercedes MB Truck Explorer - $35
Mercedes Sprinter/Vito Start Error 1.3 - $25
Mercedes Car, Truck Euro Price list 2023 - $45
Mercedes Computer Based Training CBT in English 2022 - $165
Vediamo Video Course for Beginners + 100 Gb base of files (CFF CBF SMR-F ODX) - $65
DAS FDOK/VEDOC Encrypted Random Number + MR Download Calculator 1.3 - $245
Xentry Basic PDF Book for all detailed explanation use - $199
The book consists of 143 pages: Xentry, Das, StarFinder, Wis, EPC software manuals, instructions for connecting directly to the vehicle and some basic information about CBF, CFF, SMR-D and SMR-F files.
What inside:
1. Mercedes original software icon summary (required basis)
2. Mercedes original software Xentry detailed use (set IP)
3. Mercedes original software Xentry uses detailed explanation
4. 212 Transmission computer online programming
5. Mercedes original software DAS detailed use
6. Mercedes software DAS high-rights detailed use
7. Xentry special password offline lock FBS4 key track case
8. Xentry special password shielding passenger side cushion recognition sensor case
9. HVAC222 unforces the forced opening of the air conditioning outer circulation
10. Release the instrument 120km/h speeding tone
11. Detailed explanation of Mercedes Benz (software StarFinder, WIS/EPC)
12. Some basic information about CBF, CFF, SMR-D and SMR-F files.
Vediamo Engineer System Training PDF Book for real special functions - $199
297 pages included. What inside:
1. Mercedes-Benz engineer vediamo exchange study
2. CBF CFF file default storage location
3. Vediamo establishes a connection with the vehicle
4. Connection to the vehicle
5. Establish a connection with the vehicle
6. Vediamo database
7. Vediamo data cbf, smr-d file import
8. Common control unit name (CBF, SMR-D)
9. Vediamo establishes a connection with the vehicle
10. Connection protocol selection
11. Main button function description
12. Module submenu description
13. Read and save module information
14. Reading and saving of coded data
15. Coding and saving (offline coding can be realized)
16. Fault reading and fast clearing
17. Select programming file CFF
18. 212 Turn on the turn assist light C
19. Save before SAM coding (important)
20. 212 Replacement used AIRBAG UNIT
21. 212 AIRBAG UNIT, change configuration
22. After changing the configuration, it must be locked
23. Changepoint nine gearbox programming code
24. Permanent deactivation of urea system for 166GL diesel vehicles
25. 166GL diesel vehicle with permanent contact with urea system
26. 164 diesel vehicles reset the number of start limits
27. XENTRY special functions (2014-12 and later)
28. Use DAS to reset SBC usage time (engine running)
20. 205 222 Add original factory keyless entry KG
30. 205 222 Retrofit the original factory keyless entry EIS (gateway)
31. 222 equipped with electric tailgate
32. Left front door tailgate switch wiring
33. Electric tailgate control unit circuit
34. The connection line between the rear SAM and the operation switch in the trunk
35. 222 equipped with electric tailgate EIS coding, left front door control unit coding, COMAND (HU5) control unit coding
DTS Monaco Engineer Training PDF Book for real special functions - $199
DTS Monaco is a universal engineering test terminal for the diagnosis and control function of the vehicle controller. The name Monaco is derived from the modular analyzer used in vehicle traffic. DTS Monaco covers all the tasks in the field of engineering, testing, and production test preparation. When Mercedes Benz maintenance test it is the greatest authority, the perfect support for C4 (SDconnect) and (Ecom) Hardware (at present, Das-xentry. Vediamo lower authority)
What inside:
1.Quick Test: Entire vehicle ECU quick test and the test can choose to edit more
2.Variant Coding: Coding with variation add VO- delete VO function
3.ID identification: One click to read the whole car and save all modules programmed numbers
4.Complete Variant Coding: One time to read all the ECU coding vehicle data, can be written to the vehicle again, completely off-line operation
5.Diagnostic Services: Advanced features can see your choice of internal and external data module, turn on the computer authorization (not driving license), Activate ECU, reset ECU, modify the original chassis number
6.Flash programming: Fully offline programming
7.Diagnostic Trouble Code: Diagnostic module DTC fault code
8.ECU Exchange: Two of the same ECU, by reading data import data exchange
9. Symbolic trace: Record and track the file, after repeated viewing, analysis of fault logic point
10. One key to saving the whole car code.
11. Single control unit coding
12. Introduction to DTS
13. DTS system icon introduction
14. Introduction and file path to CBF\CF\SRM-D\SMR-F
15. Common control unit name (SMD-D), (CBF)
16. DTS and Vediamo difference
17. DTS is connected to the vehicle (provided: VCI connect OK)
18. DTS is connected with the vehicle
19. DTS main interface function introduction
20. Quick Connect Test
21. Diagnostic service function
22. One key to save the whole car code
23. Whole vehicle ID hardware number Software number storage
24. Coding and saving of a single control unit
25. One-key coding for a single control unit
26. Control unit programming (212 air conditioner as an example)DTS must be exted first to load cff file, take 212 air conditioner as an example (and enter DTS again))
27. Fault reading and clearing
28. ECU data exchange (storage, read, automatic save, data writing)
29. DTS single modile code
30. Control unit DTS single module code import
31. Diagnostic service function
32. DTS Flash programming
33. DTS A key to save the whole car code
34. DTS One-click to save the whole car code
35. DTS Full vehicle code recovery single or multiple modules
36. DTS data exchange (storage, automatic save, data writing)
37. DTS data handover (storage)
38. DTS Data tracking
39. DTS Zhihua dedicated mode
40. Car coding file comparison
41. DTS Monaco template settings
42. Add/edit single model CBF or SMR-D file
43. Add car mode
44. Add car mode or project
45. DTS-Monaco Training
46. 212 add electric folding mirror (add code for gateway, instrument coding)
47. 212 Turn off the start-stop function
48. 212 Turn on auxiliary lights for corners
49. 205 Add folding rearview mirror (gateway coding, command coding)
50. 212 Keyless Entry Modification
51. 205 222 retrofitted with original factory keyless entry (circuit diagram, gateway coding, KG computer coding)
52. 222 equipped with electric tailgate (gateway coding, rear SAM coding, tailgate computer coding)
53. 205 222 equipped with electric tailgate, kick function (gateway coding, coded on the left front door, command coding, KG module coding, PTCM coding)
54. 205 equipped with electric tailgate activation auxiliary lock (after Sam coding)
55. 212 or 218 add original factory atmosphere light (gateway activation code, instrument coding, pre-Sam coding)
56. 205 Add original factory atmosphere light (circuit diagram, gateway coding, command coding)
57. DTS: Change the 205 to install the original ambient light (command code)
58. 205 Add original factory atmosphere light (coded by SAM before)
59. DTS: Add 166, 292-atmosphere lights
60. DTS: Install HU5S1 12-color ambient light (gateway)
61. DTS: Add 166,292 Ambient Light (HU5s1, Sam)
62. DTS: Add 809 version 64 color ambient light (HU55ENTRY)
63. 212 low-profile headlights upgrade high-profile headlights (instrument coding, front Sam coding, pre-Sam data write, headlight computer coding)
64. 205 retrofit seat memory (gateway coding, command coding)
65. 205,222 installed fragrance system (air conditioning coding, command coding)
66. 213 DTS is negative from fragrance (command setting code)
67. 205 installation of the Voice of Berlin (gateway coding)
68. 205 222 Install the sound of Berlin (EZS code, command code)
69. 205 installs reversing image (camera circuit diagram, gateway coding, command coding, rearview camera coding)
70. Adding auxiliary instrument to Smart 453
71. 453 retrofit image
72. 222, 205, 253 with digital tire pressure, seat ventilation
73. 213, 156 open blind spot assist
74. 166 completely canceled the urea system (engine unlock code, engine computer programming)
75. Solve 221 battery light alarm, left wheel button failure
76. Resolve 221 battery light alarm, left steering wheel button is invalid
77. 213 mechanical instruments to LCD instrument
78. Retrofit system (opening the ground light)
79. Installation of surveying system (gateway opened)
80. Adding a surround system (description process)
81. 212 Turn of seat belt sound reminder, instrument coding
82. 212 airbag unlock
83. 212 Turn off the engine fault light
84. US instrument localization (color screen)
85. Fahrenheit to Celesius
86. 205 acousto-optic synchronization enabled (reversing radar coding)
87. 212 change ESP computer chassis number
88. 212 daytime running lights are lit at night, turn on at night (write sam data)
89. 212 change the number of blinks of the turn signal
90. 205 222 change the number of blinks of the turn signal (sam coding)
91. 212 204 change the number of blinking lights (sam Code)
92. 212 turn off the function
93. 205 222 turn off the start-stop function (sam coding)
94. 213 disables start and stop
95. 205 change the host boot screen (command coding, command code)
96. HU55 boot screen change
97. 213 cancel driving to watch DVD restrictions (command code)
98. Mercedes DTS opened CARPLY
99. ME97 cancels oxygen sensor
100. Cancel 212 seat belt tensioning device
101. DTS shield 212, 166 SOS
102. 212 opening corner auxiliary light
103. 222 disables additional battery
104. EZS166 Shield A90 Anti-collision Aid System
105. GLK204 shielded passenger seat sensor
106. Mercedes-Ben C series brush hidden list
107. 205 253 ACC adaptive cruise
108. MFA 166 292 ACC Adaptive Cruise
109. HU6 code reset solution
110. Some unlocking methods for new cars
111. 177 Ambient light HU6 code
112. 177 original digital tire pressure gateway code
113. 177 Keyless Access Gateway Code 1,2
114. 177 mode HVAC unlock command
115. 177 fragrance negative ion HU6 code
116. 177 Berlin Voice Gateway
117. 177 mode Berlin voice HU6 code
118. 177 seat ventilation heating
119. 177 seat heating SAM code
120. 177 seat ventilation SAM code
121. 177 change the host boot screen
122. 177 flicker turn signal flashing times
Need it? Write to me to ask details.
  • VAG - ODIS ETKA ELSA
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Mercedes Xentry Basic Paper Book for all detailed explanation use
Mercedes Vediamo Engineer System Training Paper Book for real special functions
Mercedes DTS Monaco Engineer Training Paper Book for real special functions
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added Xentry Offline Login
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added Xentry/DAS Password generator for coding and programming
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Mercedes DTS Monaco 9 + Zen Zefi certificate (all 2022 models)
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Xentry OpenShell and PassThru 12.2022
Starfinder 2022 (wiring diagrams)
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Xentry Switcher between Star Diag C4 and C3 2022
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Price updated for DTS Monaco 9
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added Mercedes Car, Truck Euro Price list 2023
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Mercedes Remote Install – Mercedes Full Software Pack (Xentry + DAS + DTS + Vediamo) motorstate 0 783 09-27-2025, 09:38 PM
