Remote Install - Scania Multi, SDP3, XCOM, BNS II Service Tool (BST)
Scania
Remote Install - Scania Multi, SDP3, SDP2, XCOM, BNS II Service Tool (BST)
Scania Multi 10.2024 online (via remote desktop) 12 months - $135
Scania Multi 10.2024 online (via remote desktop) 3 months - $59
Scania Multi 10.2024 online (via remote desktop) 1 month - $35
Scania Multi 06.2025 - $190
Scania Multi 2022 - $65
Scania Multi 2020 - $35
Scania Multi is a car dealership aftermarket service. The program contains a catalog for the selection of spare parts and electronic manuals for repair and maintenance. Scania Multi works by VIN code and uses only the last 7 digits to decrypt the wines of a bus or truck. In the program there is a search by the part number, you can find out its applicability, as well as get information about the re-release of parts.
[Image: Scania-Multi.jpg]
Scania SDP3 2.61.1.5 for Trucks + Buses (with keygen) - $600
Scania SDP3 2.61.1.5 for Trucks (with keygen) - $500
Scania SDP3 2.58.3 Truck, Bus, Marine (with keygen) - $299
Scania SDP3 2.64.2 Truck, Bus, Marine - $155
Scania SDP3 2.54 for Truck and Bus (with keygen) - $155
Scania SDP3 2.66.3 Truck, Bus - $165
Scania SDP3 2.48 2021 - $35
SDP3 - Scania Diagnos + Programmer 3 (SDP3) software is designed for the diagnosis of Scania trucks and Scania industrial and marine engines. Connection to the electronic control units is done using the Scania VCI 2 or Scania VCI 3 interfaces. Depending on the version of the program, it supports work with all Scania trucks manufactured from 2004 to the present day.
[Image: Scania-SDP3.jpg]
Scania Flasher Master unlimited time - $2755Scania Flasher Master 1 year access - $1699Scania Flasher Master 3 month access - $845Scania Flasher Master 1 month access - $365
This software for read and write flash file for Scania ECU, with this software you don't need to use any extra tools and can use only Scania VCI2 or VCI3.
1 year access has 10 tokens-numbers for writing, reading and saving in the program. You can read from ECU and write on COO7 COO8 EMS S6 S7 S8 OPC TMS ECC.
3 and 1 months has less tokens.
Scania XCOM - $29
Scania XCOM - is a diagnostic tool to read, save, and modify ECU data such as trouble codes, parameters, statistic data etc. VCI2/VCI3 interface is used to connect to ECU via CAN protocol.
Supported modification of ECU data of the following types:
  • EMS – Engine management system
  • GMS – Gearbox management system
  • RET – Retarder system
  • AWD – All-wheel drive system
  • CLS – Clutch Control
  • EEC – Exhaust Emission Control
  • COO (COO7) – Coordinator
  • BWS (BCI1) – Bodywork system.
[Image: Scania-XCOM.jpg]
Scania Developer (CDEV - ECOM - XCOM) - $299
Scania CDEV supports the following operations:
  • Read ECU ID, data, parameters, fingerprint.
  • Read and erase DTC.
  • SparePart program all systems.
  • Gather all data for field test functions.
  • Load, modify, compare SOPS files.
Scania ECOM - is a program that, together with the VCI2, enables the communication between your PC and the control unit (EMS S6) on the engine.
You can carry out the following operations with ECOM:
  • Read stored fault codes and Freeze Frames.
  • Clear inactive fault codes.
  • Read information about stored working cycles.
  • Measure internal variables such as the engine speed, pressure, temperature and save them to a file.
  • Program certain parameters.
Scania BNS II Service Tool (BST) - $39
Scania BNS II Service Tool (BST) is a PC-based diagnostic program for troubleshooting and programming of the electrical system in the bodywork of Scania OmniCity, OmniLink, and Citywide buses.
[Image: Scania-BNS-II-Service-Tool-BST.jpg]
Scania SOPS - $59
The program encrypts/decrypts SOPS files (contains data on parameters and specifications of all blocks of trucks or buses). Files can be downloaded using Scania VCI2.
Scania SOPS Editor Euro-6 2022 Unlimited - $495
Supports EURO 6 Scania Sops File Encryptor/Descriptor.
  • Disable AdBlue
  • Disable EGR
  • Disable Immobilizer
  • Change VIN
  • Disable Nox Control
  • Disable Torque Reduction NOx Control
  • Disable Modify more than 300 other parameters...
[Image: Scania-SOPS-Editor-Euro-6.jpg]
Scania AdBlue Off Remover with short instructions - $45
[Image: Scania-Ad-Blue-Off.jpg]
Scania IMMO Pin Code Decryption - $165
It works with -  COO6, COO7, COO8, EMS.
It works with - ASSY, COO6, COO7, COO8, EMS S6/S7/S8/EMD1, LAS1/LAS2
[Image: Scania-IMMO-Pin-Code-Decryption.jpg]
Need it? Write to me to discuss.
  • VAG - ODIS ETKA ELSA
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added Scania SDP3 2.52
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Scania SDP3 2.54.2 Truck, Bus
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Scania IMMO Pin Code Decryption 4.02
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Scania SDP3 2.56 Truck, Bus
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Scania SDP3 2.56.1.2
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Scania SDP3 2.57
Price updated for
Scania SDP3 2.48 and 2.54
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Scania Multi 05.2023
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Lumbargini Remote Install — Lamborghini LaRA Software, VCI & Wiring Diagrams motorstate 5 1,271 09-12-2026, 06:48 PM
Last Post: nehadutt
Scania Remote Install – Scania Full Software Pack (Multi + SDP3 + SOPS Editor) motorstate 4 706 09-08-2026, 07:34 PM
Last Post: rubberglobe
Peugeot Remote install - PSA Peugeot Citroen - DiagBox, Service Box, LASER, Sedre motorstate 16 5,990 08-13-2026, 10:25 PM
Last Post: Ramika apte
Jaguar Remote Install – JLR Full Software Pack (TOPIx + Pathfinder + SDD + CCF Editor) motorstate 1 676 08-05-2026, 12:29 AM
Last Post: ruhi02
Volvo Remote Install – Volvo Trucks Full Software Pack (PTT + APCI + DevTool + Flash + EWD) motorstate 1 674 06-30-2026, 10:27 PM
Last Post: rakhisharmax
  Remote Install - Volvo Premium Tech Tool (PTT) + DevTool, Vodia, Impact, Prosis, VIDA motorstate 52 15,298 10-07-2025, 09:27 PM
Nissan Remote Install - Nissan Consult III, Fast, Diesel UD EPC, Forklift, NERS, Manuals motorstate 10 4,749 10-06-2025, 11:10 PM
CAT Remote Install - Caterpillar ET, SIS, HCIS, VIMS, CDVR, HIS, MCFE, Flash-Trim files motorstate 23 7,596 10-04-2025, 09:12 PM
Cummins Remote Install - Cummins Insite, Calterm, QuickServe, Incal, Inpower, PowerSpec motorstate 30 11,711 10-02-2025, 08:43 PM
Last Post: motoricko
Porshe Remote Install – Porsche Full Software Pack (PIWIS III + PET2 + Manuals) motorstate 0 884 10-01-2025, 10:32 PM
