Cummins InPower Pro 14.5 (installation files)
Cummins
InPower provides the following functions for monitored equipment:
•    Direct connection capability from a personal computer to PowerCommand genset controls, transfer controls, and system controls;
•    Allows the monitored equipment to send alarm information to a connected computer.
•    Configurable for units of measurement, and level of user access (read only, read/change values, administrator).
•    Adjustment of nearly every adjustment parameter within the connected control system, including parameters such as voltage and frequency levels, gains, protection set-points and other values.
•    Convenient programming of configurable inputs in the controllers.
•    Viewing of equipment history, fault codes, and data associated with fault codes.
•    Generates reports of monitored data
•    Allows released firmware upgrades on Power Command genset controls.
•    Plot critical parameters in a strip chart format, and export data to 3rd party software tools for manipulation and viewing.
•    Simulate fault conditions in genset controls in compliance to NFPA 110 requirements to demonstrate functionality of the controller and monitoring equipment in a facility.
[Image: bce9ef7d112c8bb3cd0026aa8a8898eb.png]
Need it? Push buttons Rate (Reputation) and Thanks, PM for pass.
Cummins InPower.txt
  • VAG - ODIS ETKA ELSA
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
The link is working again
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Cummins Cummins InPower Pro v11.0 + Activation Thunder 0 4,385 05-20-2016, 01:01 AM
