Remote Install - Detroit DDDL, DDDE, Backdoor, DDEC, Manuals, EPC, Checksum Updater
Remote Install - Detroit Diesel Diagnostic Link DDDL, DDDE, Backdoor, DDEC, Manuals, EPC, Checksum Updater, Magic Tuner Flash Tool
Detroit Diesel Diagnostic Link DDDL 8.22 Full (Level 10 10 10) +Troubleshooting / Programming (with keygen locked 1 PC) - $1379
Detroit Diesel Diagnostic Link DDDL 8.20 2024 (Level 10 10 10) + 06.2023 Troubleshooting / Programming - $135
Detroit Diesel Diagnostic Link DDDL 8.20 (only activation) - $99
Detroit Diesel Diagnostic Link DDDL 8.09 - $99
Detroit Diesel Diagnostic Link DDDL 6.5 - $50
Detroit Diesel Diagnostic Link DDDL 8.13 SP3 (Level 10-10-10) MAX Edition + Backdoor - $135
This DDDL kit allow to increase the odometer value. This can only be done on those СPC software versions where it is possible to increase the odometer by regular way (i.e. ""Actions - Set Odometer"" menu is available)
DDDL 8.09 - $99
Program for diagnostics and firmware Detroit Diesel engines
[Image: Detroit-Diesel-Diagnostic-Link-DDDL.jpg]
Magic Tuner Flash Tool 3.0 (for Detroit, Maxxforce, Paccar, Caterpillar) - $135
Magic Tuner Flash Tool 2.1 (for Detroit, Maxxforce, Paccar, Caterpillar) (with keygen locked for 1 PC) - $465
Magic Tuner Flash Tool 2.1 (for Detroit, Maxxforce, Paccar, Caterpillar) - $115
Magic Tuner Flash Pro - $299
Included: Magic Tuner Flash Tool v1, v2.1, v2.2, Developer Tool v3, Pro Tool.
It works with:
Detroit MCM: EPA7, EPA10, GHG14, GHG17
Detroit ACM: EPA7, EPA10, GHG14, GHG17
MaxxForce: EDC17, EDC7, EIM7, S3V8, S4I6, S4V6, S4I60, S4I61, S4I6Special, S8V8, DCU, HICM, CECv10, ECMVW, NECM2, IDM2, NCEC1
Cummins: ECM, ACM
Vovlo: EMS2-2, EMS2-3
This tool can flash the ECU through the diagnostic connector so as not to remove the ECU, not to open, but simply flash them with a binary (*.bin) using any adapter, for example, Nexiq.
Works for:
  • Detroit MCM (EPA7, EPA10, GHG14, GHG17), ACM (EPA7, EPA10, GHG14, GHG17)
  • Maxxforce (EDC17, EDC7, EIM7, S3V8, S4I6, S4I6Special, NECM2, IDM2, S8V8)
  • Paccar
  • Caterpillar CAT AG
[Image: Magic-Tuner-Flash-Tool.jpg]
Detroit DD15 DPF, EGR, SCR Performance Tuning Files - $165
Files for delete parameters, manual transmission. There are 3 files for that work. These deletes are for units from 2010 to 2013.
Detroit DD13 DPF, EGR, SCR Performance Tuning Files - $165
Detroit DDEC IV - V Tuning files - $165
List of files.
Detroit DD15/S60 DPF EGR SCR Delete files - $165
Detroit DD15 EPA13 Delete files for Magic Tuner - $155
Detroit DD15 EPA10 Delete files for Magic Tuner - $245
Detroit Calibration Files - $99
Calibration Files Collection.
Detroit Diesel Calibration Tool DDCT 4.5 - $75
The DDC Cal Tool provides a programmable software interface to the Electronic Control Module (ECM) in an engine. Using the DDC Cal Tool, you can:
  • View and edit the control parameters in the ECM to optimize the control logic
  • View instrumentation variables, such as rpm or fluid temperatures and pressures, while the engine is running.
[Image: Detroit-DDCT.jpg]
Detroit Diesel Reprogramming System DDRS 7.11 - 75
Detroit Diesel Reprogramming System DDRS is a diagnostic program that is designed to schedule Detroit Diesel engines. It contains all data diagnostics and programming operations for all Detroit Diesel diesel engines. The main feature of it is that the application is an electronic tool for servicing the engine family EPA07, EPA10, GHG14 equipped with engines (S-60, MBE4000, MBE900, DD13, DD15, DD16).
Detroit Diesel Drumroll Engineering DDDE - $39
Detroit Diesel Drumroll Engineering (DDDE) is a diagnostic software that includes:
  • View information about connected computers
  • Performing Standard DTC Operations
  • Performing standard and advanced troubleshooting methods
  • Reading the value of variables in real-time and their graphical display
  • Configure and manage settings
  • Performing service procedures.
[[Image: Detroit-Diesel-Drumroll-Engineering-DDDE.jpg]
Detroit Backdoor - $75
It is needed to unlock all the parameters.
Detroit DDEC Reports 9.03 - $115
Detroit DDEC Reports 9.01 - $35
DDEC Reports is a fleet management application that includes support for Detroit engine controllers: DDEC 3-5 ECU, VCU, CPC2, CPC02T, CPC04T, CPC302T, and CPC501T.
Detroit Diesel 60 Series Service Manual - $65
[Image: Detroit-Diesel-60-Series-Service-Manual.jpg]
Detroit Diesel ECU Checksum Updater 1.5 - $1639
It's a tool that updates the checksum of the ECU's specification files when we modify them. When you modify the file, you just have to drag it to the application and that's it. Otherwise, the DDDL will give you an error.
[Image: Detroit-Ecu-Checksum-Updater.jpg]
Detroit Diesel Power Service Literature Off-Highway - $85
[Image: Detroit-Diesel-Power-Service-Literature-Off-Highway.jpg]
Detroit Diesel Wiring Diagrams - $117
[Image: Detroit-Diesel-Wiring-Diagrams.jpg]
Detroit Diesel All Series Service Manual - $185
Detroit Full Set Shop Manual - $225
Contains: Workshop Manual, Repair Manual, Wiring Schematic, Service Bulletins, Parts Catalog
[Image: Detroit-Full-Set-Shop-Manual.jpg]
  • VAG - ODIS ETKA ELSA
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added DDDL 8.16 SP4
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added Detroit Diesel Diagnostic Link DDDL 8.17
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Detroit Diesel Diagnostic Link DDDL 8.18
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Detroit DDDL 8.19
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Added
Detroit DDDL 8.20 2024 with Grayed Parameters
  • BMW - ISTA E-Sys
  • Porsche - Piwis
  • Activation Launch
Nissan Remote Install - Nissan Consult III, Fast, Diesel UD EPC, Forklift, NERS, Manuals motorstate 10 3,726 10-06-2025, 11:10 PM
Porshe Remote Install – Porsche Full Software Pack (PIWIS III + PET2 + Manuals) motorstate 0 446 10-01-2025, 10:32 PM
Misubshi Remote Install – Mitsubishi Full Software Pack (MUT-III + ASA + Manuals) motorstate 0 256 09-30-2025, 09:17 PM
VW Remote Install – VAG Full Software Pack (ODIS-S + ODIS-E + iDEX + PETKA + Manuals) motorstate 0 346 09-29-2025, 10:07 PM
Honda Remote Install - Honda HDS, I-HDS, EPC, Manuals, IMMO Code Generator motorstate 12 3,814 09-26-2025, 01:26 AM
  Remote Install - AGCO Parts Books, EDT, SISU, Epsilon, Manuals motorstate 14 5,278 09-19-2025, 07:41 PM
Ford Remote Install – Ford Full Software Pack (IDS/FDRS/FJDS + Etis + TIS Manuals) motorstate 0 447 09-16-2025, 09:38 PM
  Remote Install – Case Full Software Pack (CNH EST + eTimGo + Manuals) motorstate 0 415 09-13-2025, 08:51 PM
  Remote Install - JCB Parts Plus, Service Parts Pro, Service Manuals, ServiceMaster motorstate 25 6,634 08-14-2025, 11:57 PM
  Remote Install - CLARK ForkLift PartsPro Plus, Juniper, Service, Operators Manuals motorstate 12 2,522 08-09-2025, 08:53 PM
