The CAT ET Software can work for Perkins
Cat Caterpillar ET 2023A Electronic Technician Diagnostic Software is lastest version for CAT Caterpillar ET tool, Support Multi-languages:English, Chinese, Danish, French, German, Italian, Japanese, Portuguese, Russian, Spanish , OS:Windows 7 32 bit, Windows 7 64 bit, Windows 8/8.1 32 bit, Windows 8/8.1 64 bit, Windows 10 32 bit, Windows 10 64 bit, and the software include the 10 factory password generator .
Some customer asked the 2023A cat software can work with the Perkins tool, the answer is yes.
If you need,you can search on our store directly : www.obd2.ltd
Perkins EST Interface Diagnostic Tool is not with wifi or Bluetooth. With Fast USB communication , Operate System:Windows7 and win10, Compatible Vehicle: For Trucks, Excavators, Air Compressors, Ships, Drilling Rigs, Support Multi-Languages: English, Chinese, Danish, French, German, Italian, Japanese, Portuguese, Russian, Spanish
Perkins function as below:
Override Powerwizard level three passwords
Configure and/or change system parameters
Display, graph and record logs of parameter status
Display the status of a group of parameters (temperatures, pressures, etc)
View and clear active and logged diagnostic codes
View and clear active and logged event codes
Display, view or change the current Configuration File or Base level Flash File
Upload, download and save configuration files
View a list of irregularities logged by the ECM (engine control module)
Perform diagnostic tests
Perform calibrations
Print reports and diagnostic results.
  Latest Caterpillar ET Software to work with CAT/CAT3 Truck Scanner Daysi 0 1,247 07-18-2023, 06:55 PM
Last Post: Daysi
