WABCO Diagnostic Software
WABCO System Diagnostics (SD) consists of a range of Windows based software solutions and all the hardware necessary to carry out diagnostic work on every WABCO system.
A wide range of diagnostic hardware completes the System Diagnostics package:
easy-to-use blink code plug, digital testers, conformity test unit, adapters and cables, and a complete test bench
(05-31-2023, 06:58 PM)Daysi Wrote: WABCO System Diagnostics (SD) consists of a range of Windows based software solutions and all the hardware necessary to carry out diagnostic work on every WABCO system.
Meritor WABCO TOOLBOX software provides PC diagnostics for SmartTrac, including Tractor and Trailer Pneumatic ABS, Trailer RSSplus, Trailer EBS, Hydraulic ABS and Hydraulic Power Brake (HPB), as well as OnGuard, OnLane and OptiRide Electronically Controlled Air Suspension (ECAS).
Streamline your diagnostic time, increase uptime and put safer trucks on the road with TOOLBOX software solutions for Meritor WABCO components.
Features & Benefits
The program provides the following basic functions:
Displays both static and dynamic information from the system under test
Displays both active and stored system faults, as well as the appropriate repair instructions
Activates system components to verify system integrity, correct component operation and installation wiring
Provides direct digital access to product maintenance manuals
Offers easy lookup of Install Instruction HTML files
Reverse Diagnostic Trouble Code (DTC) Lookup
Aftermarket ECU Programming Updates
New Key Features
Additional Pneumatic ABS ECU (E8)
New inclusion of Electronic Braking System (EBS) ECU
OnGuardACTIVE Diagnostics
Hydraulic Power Brake (HBP) and Hydraulic ABS 500 kBaud Support
Improved Quick Start Guide
J1939 Bus Monitor 500 kBaud
Requirements
Microsoft Windows XP, Vista, or Windows 7 operating system
1 GB RAM
100 MB HD space for full installation
RP1210 compliant vehicle datalink adapter (VDA) for SAE J1939, J1708/J1587 or PLC
USB Port or Serial Port for RP1210 adapter
  WABCO DIAGNOSTIC KIT FOR WABCO Trailer And Truck Diagnostic Tool Martin56 0 1,280 03-20-2023, 11:03 PM
Last Post: Martin56
