TecDoc CATALOG (04.2012) Multilanguage
TecDoc CATALOG [04.2012] Multilanguage
[Image: 167ui9y.png]
[Image: td01.png]
Type: Spare Part Catalog
OS: Windows XP, vista,Windows7
Update: 04.2012
Your advantage:
With the fourth CATALOG DVD in the year 2010, we anticipate that TecDoc PHOENIX will be the basis on which the production of the DVD will be based. With PHOENIX, extensive changes with regards to structure and also contents of the TecDoc data basis will take effect. As a user of the CATALOG, you will benefit from so many new possibilities.
Homepage:
http://www.tecdoc.net
TecDoc CATALOG [04.2012] TORRENT.rar
hi, someone gave me the original disc, 4 dvd
after install it's asking me for activation
how do i proceed from there ?
thx in advance
(01-05-2012, 10:21 AM)mike Wrote: hi, someone gave me the original disc, 4 dvd
thx in advance
Read post #1 with more attention. Read the instructions from the CRACK archive.Undecided
installed successfully, thanks so much. but during the operation, it will warn "Fehler 110", a wrong. is there any solution ?
(01-07-2012, 09:34 PM)sev17teen Wrote: installed successfully, thanks so much. but during the operation, it will warn "Fehler 110", a wrong. is there any solution ?
You use WIN 7?
I have identical problem.
Program works, but this error non-stop pop-up.
In XP OS no any problem, works fine except teh data.
Try this NEW CRACK:
NEW CRACK TECDOC 01.2012.txt
Downloaded: 400 times
(01-08-2012, 12:33 AM)TestPoint Wrote: Try this NEW CRACK:
I try this crack from other forum, and work only with XP OS.
You use WIN 7?
No,i used it on XP. and now, i will try the new crack from Testpoint, thanks.
thanks for your new crack.Give5
"Fehler 110" disappear,and never appear.
"Fehler 6006" appearConfused
Yes I see Sad I don't have another one Sad
I use Win 7 Ultimate x86
For me it works doing this steps.
1. I've copied the file 'TecDocPatch.exe' in 'pd' directory and run it. Just clicked next, next....and Finish. No change in install process.
2. I've copied the '.ocx' files in 'system32'
3.I've copied and replaced files from "Final Crack! TecDoc 2012" directory in "pb" directory.
4.I've changed the compatibility mode to Windows XP SP2 and checked 'Run as administrator'
I hope my post is useful.
TECDOC_01_2012_CRACK.txt
Downloaded: 299 times
  TecDoc CATALOG 04/2011 Multilanguage TestPoint 39 55,308 04-14-2012, 04:00 AM
Last Post: scorpio73
  TecDoc CATALOG 03/2011 Multilanguage TestPoint 3 10,100 09-15-2011, 06:09 PM
Last Post: COMBRA
  TecDoc CATALOG 02/2011 Multilanguage + FINAL CRACK TestPoint 0 6,441 09-02-2011, 04:50 PM
Last Post: TestPoint
