Smart Forum
Facebook
Auto-Software
Auto-file.ORG
EPC SOFTWARE
Support US
- 0 Vote(s) - 0 Average
- 1
- 2
- 3
- 4
- 5
VAS 6154 clone for Porsche Piwis 3
Threads: 100
0
Given 1 thank(s) in 1 post(s)
Hi, I have set up a
Porsche Piwis3 diagnostic system. I need to configure the VAS6154 clone so that it is recognised by the piwis 3.
It works perfectly with the original Actia PT3G VCI.
Can anyone help? Help is much appreciated.
Threads: 0
1
Original Factory New VW VAS 6154 VAS6154/A Interface
The VAS6154A Diagnostic Interface is the latest official diagnostic tool for use with ODIS (Offboard Diagnostic Information System), succeeding the VAS6154. This interface is fully compatible with Microsoft Windows 10, while the older VAS5154 is not officially supported with ODIS versions running on Windows 10. Additionally, VAS5154 is incompatible with newer vehicle diagnostic protocols, particularly Vehicle Diagnostic Protection (SFD) encryption used on newer platforms.
VAS6154 can supports DOIP dignosis.
VAS6154 supports online function, but you need to get online account by yourself!
Softwares:
-ODIS V23.01
-Engineering V17.0.1
(U-Disk is ODIS V23.01 with keygen and Engineering V17.0.1 with keygen, you can use keygen to activate by yourself)
VAS6154 Diagnostic Tool Features
VAS6154 Diagnostic Tool Fault code reading, fault clearing, service light reset, throttle adaptation, brain (ECU) coding, guided function, automatic vehicle recognition, data analysis with live value display, steering problems with steering angle calibration, injector coding after injector replacement or repair, You can perform DPF regeneration for the full particulate filter, brake puller release settings required for pad replacement, transmission calibration, transmission adaptations after transmission repair and special parameterization operations and activate a number of hidden features.
Threads: 0
0
Given 0 thank(s) in 0 post(s)
Hey everyone, I'm facing a tricky Piwis 3 setup. My VAS6154 clone isn't being recognized, though my Actia PT3G VCI works fine. It's like trying to navigate a steep hill in Slope Game without the right controls! Any gurus out there who can offer advice on configuring the VAS6154 for Piwis 3? Really appreciate any help you can provide.
Threads: 0
0
My mind wandered to the moment I tried a DIY tool that promised big results and found it unreliable, a clumsy detour that taught patience. Slice Master shows up in passing as a nod to craftsmanship while we weigh risk and value in this field. I once faced a similar issue when a cheaper adapter corrupted vehicle data, teaching me to verify sources and ethics before diving in.
Threads: 1
0
If you want to run a vas 6154 on Piwis, you'll need original hardware. I can run the original Vas 6154 on Piwis.
Threads: 0
0
I’ve used a similar tool in a workshop, and good online access makes diagnostics smoother, but I value learning the basics offline first. If you’re into hands-on challenges, Geometry Dash’s levels teach timing and precision—great practice for patience and focus. Try tackling a few user-made stages to build rhythm before pacing yourself through tougher official runs. Geometry Dash
Threads: 0
0
Sometimes the best games aren’t the ones with the fanciest graphics—they’re the ones that create a simple goal, a playful challenge, and lots of memorable moments with friends. One great example is kick the buddy, a lightweight, physics-based game where your main job is to interact, experiment, and try to land your “buddy” in just the right way.
Threads: 0
0
I can relate to the frustration of configuring diagnostic tools. I once spent hours trying to get a generic OBD2 scanner to work with my old car. The software compatibility issues were a nightmare. It eventually led me to appreciate simpler forms of entertainment while waiting for downloads and driver updates. Sometimes, just unwinding with a game like Block Blast helps clear my head before tackling technical problems again. Hopefully, Martin56 finds a solution soon. Dealing with these tech hurdles can be incredibly time-consuming.
Threads: 0
0
Ever feel the need for a quick burst of adrenaline, fueled by catchy music and deceptively simple gameplay? Then look no further than geometry dash, a rhythm-based platformer that's as addictive as it is challenging.
Threads: 0
0
07-09-2026, 05:16 PM
(This post was last modified: 07-09-2026, 05:16 PM by yuvi001.)
(05-14-2026, 08:02 PM)Poppyirby Wrote: Ever feel the need for a quick burst of adrenaline, fueled by catchy music and deceptively simple gameplay? Then look no further than geometry dash, a rhythm-based platformer that's as addictive as it is challenging.
Seeking an unforgettable experience in the capital? Meeting Vip Delhi Call Girls is the perfect way to elevate your social life. Their grace and elegance bring a touch of class to any outing, leaving you feeling entirely refreshed and satisfied.
| Users browsing this thread: |
