How to Fix VXDIAG Benz C6: No device connection, device ping failed Error
VXDIAG Benz C6 No device connection, device ping failed error usually indicates a communication problem between the diagnostic tool and the vehicle. Here is a step-by-step guide to troubleshoot and resolve this issue:
1. Check the connections: Make sure all connections between the VCI, OBD-II port, and the vehicle are secure. Look for any damaged cables or connectors that may be preventing communication.
2. Power: Many diagnostic functions require power to the OBD-II port, so make sure your vehicle's ignition is on or the engine is running.
3. Driver Update: Make sure your VXDIAG device drivers are up to date. Visit the manufacturer's website to check for available updates.
4. USE THE LATEST SOFTWARE: Make sure you are using the latest version of the VX Manager software. Older versions may cause compatibility issues.
5. CHECK VEHICLE COMPATIBILITY: Make sure the vehicle you want to diagnose is compatible with VXDIAG Benz C6. Some older models or certain configurations may not be supported.
6. Test on a different vehicle: If possible, test VXDIAG on a different vehicle to determine if the issue is with the tool or with a specific vehicle.
7. Firewall/Security Software: Temporarily disable any firewall or antivirus software on your computer as they may interfere with communication between the VCI and the vehicle.
8. Reinstall VX Manager: Uninstall and reinstall the VX Manager software to reset any settings or files that may be corrupted.
9. Reset Device: As a last resort, you can reset your VXDIAG device to factory settings. Please note that all settings and data will be deleted.
10. Contact Support: If the issue persists, your manufacturer's technical support may be able to help or provide assistance if necessary. Please call
and follow the steps below. If necessary, seek further assistance.
  ICOM A3 PRO+ Troubleshooting: Device Not Working Martin56 0 566 08-07-2024, 07:12 PM
Last Post: Martin56
