Mmoexp-Lightning Spear Amazon Build — Dominate Path of Exile 2 with Lightning Power
Path of Exile 2's patch 0.3.1, Echoes of the Void, has shaken up the meta in a big way. Few builds have benefited as dramatically as the Huntress, whose Lightning Spear Amazon variant now stands among the deadliest endgame destroyers in the game. With electrified spears that fork, chain, and pierce through entire screens of enemies, this build transforms your character into a living thunderstorm—an unstoppable stormfront of POE2 Currency  elemental fury.
Whether you're starting fresh in the new endgame system or pushing the hardest Waystones in the Void Depths, the Lightning Spear Amazon offers unmatched clear speed, scalable single-target damage, and surprising survivability through agile positioning and evasion synergy. If your old build can't keep pace with Path of Exile 2's power curve, it's time to plug in and channel pure voltage.
Why Lightning Spear Amazon Dominates Patch 0.3.1
The 0.3.1 update redefined projectile-based skills, giving the Huntress class a remarkable edge. Lightning Spear—once a solid but situational choice—has become an apex skill through three crucial mechanical changes:
Fork and Chain Improvements: Projectiles now benefit from additional scaling options and smarter targeting behavior, allowing spears to chain through enemy clusters seamlessly.
Lightning Damage Overhaul: The patch introduced improved scaling with Shock effects and added multipliers that greatly increase the payoff for crit and penetration stacking.
Ascendancy Web Synergy: The new web system amplifies lightning and projectile interactions, rewarding investment in both offense and agility.
Combined, these updates create a skill that clears maps faster than ever, deletes bosses with massive burst potential, and remains nimble enough to survive the new endgame's lethal encounters.
Core Mechanics and Playstyle
At its heart, the Lightning Spear Amazon thrives on speed and precision. Every cast releases a spear that splits into multiple bolts of lightning, chaining across packs and shocking everything in its path. You don't just attack—you conduct a storm.
Here's how the playstyle breaks down:
Mapping: You'll dart through areas at high velocity, tossing Lightning Spears that annihilate packs before they even register your presence. The chaining and forking effects ensure full coverage, making backtracking unnecessary.
Bossing: Against single targets, Lightning Spear's inherent projectile count and Shock scaling combine to deliver explosive burst damage. By preloading spears and positioning for maximum overlap, you can melt bosses in seconds.
Defense: Instead of relying on heavy armor or block, this build excels through evasion, dodge, and intelligent positioning. You're light on your feet, and your enemies never quite land a hit.
The rhythm is fluid and fast—an exhilarating balance between deadly aggression and elegant movement.
Skill Setup and Gems
The build centers on Lightning Spear as your primary skill, supported by the following setup:
Main Skill Links: Lightning Spear – Chain Support – Fork Support – Lightning Penetration – Increased Critical Damage – Elemental Focus.
Utility Skills:
Dash or Blink Arrow for mobility.
Wrath as your aura for maximum lightning scaling.
Sniper's Mark for bosses to enhance projectile hits.
Call of the Storm for supplemental Shock chance and visual synergy.
Path of Exile 2's reworked gem leveling system allows you to upgrade or alter the properties of your skill directly, giving players deeper customization options. Focus your upgrades on projectile count, fork behavior, and Shock effect duration to maximize both crowd control and burst potential.
Gear and Stat Priorities
The Lightning Spear Amazon doesn't require mirror-tier gear to shine, but optimization takes it from great to godlike. Your main priorities are:
Weapon: A high elemental-damage javelin with +% Lightning Damage, Critical Strike Chance, and Projectile Speed. The new unique Stormpiercer is ideal for scaling chain distance and Shock effect.
Armor: Focus on evasion bases with increased elemental damage and resistances.
Jewelry: Rings and amulets with Lightning Penetration, Projectile Damage, and +1 to all Lightning Skill Gems.
Flasks: Instant Life Flask, Silver Flask for speed, and a Diamond Flask for critical reliability.
Once fully optimized, the build can scale comfortably past 10 million DPS, obliterating bosses and mapping content at breakneck speed.
Ascendancy Pathing
With Path of Exile 2's Ascendancy Web, you'll want to connect key Huntress nodes that boost both your offensive and defensive toolkit:
Lightning Mastery: Increases Shock effect and adds a chance to apply it on non-critical hits.
Projectile Precision: Improves projectile speed, critical chance, and hit consistency.
Evasive Instinct: Grants dodge and movement bonuses when not taking damage recently.
Conductive Charge: Converts Shock chance into bonus damage and penetration for lightning skills.
This web synergy lets you sustain mobility while scaling your lightning damage exponentially. It's one of the most well-balanced ascendancy progressions in the game right now.
Endgame and Waystones
Patch 0.3.1's expanded endgame content—particularly the Waystone progression and Echoed Delves—demands builds that can adapt quickly and hit hard. The Lightning Spear Amazon does both effortlessly.
In Waystone tiers 15 to 20, mapping efficiency becomes paramount. The build's fork-chaining system lets you clear entire screens with a single cast, while bosses and rare packs melt under overlapping spear explosions. For Delves, the long-range projectiles and flexible positioning help you engage enemies safely while keeping up your Shock uptime.
You can comfortably tackle T20+ Waystones with only moderate investment, and full-optimized versions will even handle Void-tier encounters and Echo bosses with ease.
Pros and Cons
Pros:
Blistering map clear speed.
Extremely scalable single-target DPS.
Safe, high-mobility playstyle.
Excellent synergy with new gem and ascendancy systems.
Cons:
Reliant on positioning; can be punished if cornered.
Evasion-based defense requires attention to flask uptime.
Gear-dependent past midgame if aiming for 10M+ DPS.
Final Thoughts
Path of Exile 2's Echoes of the Void has breathed new life into many archetypes, but none embody its energy quite like the Lightning Spear Amazon. Fast, furious, and visually spectacular, it captures the essence of what makes PoE2's combat so addictive—depth, fluidity, and the thrill of raw destructive power.
If you're ready to become a living conduit for the storm, now's the time. Grab your spear, charge your Wrath aura, and [/url][url=https://www.mmoexp.com/Poe-2/Currency.html]buy Path of Exile 2 Currency  carve a path of thunder through Wraeclast. The Void is listening—and it's ready to echo your lightning.
Early references to full size sex dolls in the United States appear in the late nineteenth and early twentieth centuries, influenced by similar developments in Europe. These early forms were rudimentary and often handmade, constructed from cloth, leather, or rubber. They were rarely discussed openly and existed largely in secrecy, reflecting the conservative sexual norms of the era. In the U.S., strict obscenity laws and social taboos meant that such objects were neither advertised nor widely distributed, remaining confined to underground markets or private use.
Would you accept a half body sexdoll as your companion?
BMW 04 530i M54 hit by lightning, need ista P and HELP! mkinn 0 1,599 12-01-2021, 03:18 PM
Last Post: mkinn
