IGGM | Cheap ARC Raiders Riven Tides Blueprints - Grab 8% off
Players familiar with ARC Raiders Riven Tides know that blueprints are the core resource that truly differentiates players' combat power. Most powerful weapons and high-tier attachments in the game cannot be obtained directly; they can only be acquired through rare blueprints that unlock permanent crafting access. To escape the limitations of relying on luck for drops and inconsistent equipment in matches, collecting all the current meta blueprints is essential for all players to reach endgame.
The most popular Riven Tides blueprints:
1. Dolabra: An experimental weapon that can either fire a wide short range blast, or be focused to fire a tight medium range beam of heat.
2. Looting Mk. 3 (SURVIVOR): A heavy-duty pack mule augment. Large weight capacity and large backpack space.
3. Wolfpack: A grenade that scatters into multiple homing missiles, each one targeting ARC and dealing explosive damage on impact.
4. Tempest: The Tempest is a fully-automatic Assault Rifle that uses Medium Ammo. Has moderate fire rate and accuracy.
5. Rascal: Fires explosive projectiles that only detonate when hitting ARC.
IGGM Discord - ARC Raiders Riven Tides Blueprints Giveaways:
Thank you to ARC Raiders players for your support of IGGM, we are launching a Riven Tides Blueprint giveaway event.
20 Winners Will Receive Total:
● 20 Looting Mk. 3 (SURVIVOR)
● 20 Rascal
● 20 Dolabra
● 20 Tempest
Each one get  1 ( [BluePrint] Looting Mk. 3 (SURVIVOR)+[BluePrint] Tempest+[BluePrint] Rascal+[BluePrint] Dolabra )
How to enter: Join the IGGM Discord, find the ARC Raiders section, and leave a like to participate.
A total of twenty winners will be selected. We will notify the winners within a few days, so please participate actively!
[Image: d3a8a55776a74c312672f20cf6d72aa9.png]
Currently, Rascal blueprint and Extended Barrel III blueprint are popular and practical combination across the server, and the preferred choice for countless high-level players. IGGM can provide Rascal blueprint and Extended Barrel III blueprint, with ample stock and secure transactions, helping players skip the tedious farming process and quickly achieve full-powered combat capabilities.
Rascal is the most balanced and powerful damage-dealing weapon in Riven Tides, suitable for both solo challenges and team battles. This lightweight grenade launcher is agile and has a low loadout, minimizing equipment weight. It reliably penetrates armor and suppresses groups of enemies, dealing high damage to both heavily armored ARC units and elite ARCs.
Compared to the cumbersome handling and poor mobility of heavy weapons, Rascal balances high damage output with agile maneuverability, offering a very high margin for error. However, its blueprint drop rate is extremely low, lacking a stable farming method. It's almost impossible to obtain in regular matches, and many players, even after long-term grinding, still cannot unlock the permanent recipe, relying solely on temporary loot, resulting in poor match stability. Owning Rascal blueprint allows for permanent crafting, completely eliminating the reliance on random equipment drops.
Extended Barrel III blueprint, used with Rascal, is currently the most crucial high-level attachment blueprint and a key item for maximizing the weapon's potential. As a max-level long barrel attachment, it significantly increases bullet velocity and optimizes long-range damage drop-off, perfectly compensating for Rascal weak mid-to-long-range damage. For detailed acquisition methods, please view the related post: Why Every Build Needs It: How to Find Extended Barrel III Blueprint in ARC Raiders?
After equipping, weapon accuracy and effective combat range are comprehensively upgraded, providing ample close-range burst damage and stable long-range suppression, resulting in a qualitative improvement in overall feel and combat effectiveness. This top-tier accessory blueprint is a high-level rare drop, extremely difficult to obtain, and the time-consuming grinding is very inefficient, which is the main reason why many players cannot achieve top-tier equipment.
[Image: c596413513676f458d754ff67269a949.png]
Using the two blueprints together creates an unbeatable output combination, suitable for all difficulty dungeons and combat scenarios, comprehensively improving the win rate. If you want to quickly collect core top-tier blueprints without grinding or failures, and directly unlock a permanently fully equipped system, then IGGM ARC Raiders Blueprints are the priority. Order now and enter the discount code ARC8 to enjoy an 8% discount.
IGGM - The Best Place to Buy ARC Raiders Blueprints
For players seeking powerful weapon blueprints for ARC Raiders, IGGM is a hassle-free, efficient, and cost-effective trading platform, making it the top choice due to its numerous core advantages.
[1] Lightning-fast Delivery, Max Efficiency
The platform boasts exceptional order processing speed, delivering ARC Raiders blueprints in as little as 10 minutes. The entire process is simple and requires minimal waiting.
[2] Affordable Prices, Higher Cost-Effectiveness
Compared to similar platforms, IGGM offers more competitive pricing for blueprints, allowing players to acquire desired items at a lower cost and enhance their gaming experience with less expense, resulting in outstanding cost-effectiveness.
[3] Convenient Payment, Suitable for Global Players
The buy process is clear and easy to understand, with zero operational barriers. The platform supports multiple mainstream payment methods such as PayPal, Apple Pay, and Klarna, fully satisfying the payment options of different players, making ordering smoother and transactions more secure.
[4] Real User Testimonials and Reputation
"I have buyed several times, several different weapons, several different packages. They're always right on the money. Delivery is super super fast. I'm just really really impressed by the service they give me. Thank you guys, and I'll keep buying in the future."
"Arc Raiders delivery Received order quick and it was accurate"
The ratings differ across different review platforms: IGGM received excellent ratings on Trustpilot, while on reviews.co. The rating is low. This is because reviews.co has limited credibility and recognition, easily collecting negative feedback, and its reference value is low.
[5] Transparent and comprehensive IGGM Refund Policy
If the blueprint is not delivered or does not match the description due to platform reasons, you can apply for a refund through 24/7 online customer service or email. The full amount will be refunded to the original payment method without handling fees. If the refund is applied for for personal reasons, the corresponding handling fee will be charged according to the rules.
[6] Authoritative certification, safe and reliable
IGGM maintains a high score of 4.8/5 on Trustpilot, with more than 170,000 real certified reviews; at the same time, it has passed APIVoid and ScamAdviser 100% safe and reliable certification, with formal qualifications and guaranteed transactions.
Summary:
Buying ARC Raiders weapon blueprints on IGGM is affordable, safe, and funds are guaranteed. As a mature and professional game item trading platform, IGGM continues to provide players with a stable, efficient, and high-quality service experience. Therefore, it is recommended to add IGGM to your Google Preferred Source to get platform events, item updates, and the latest news as soon as possible, ensuring you don't miss any benefits.
[Image: 146bb1dd0b7ba59e9f065c03455e15e0.png]
IGGM offers a full range of popular blueprints for ARC Raiders Riven Tides, including Rascal blueprint, Extended Barrel III blueprint, and various high-tier weapon and accessory blueprints. The entire transaction is safe and reliable, with efficient and fast delivery. No need to repeatedly grind for luck; get all the essential items for the season in one place, allowing you to easily lead the server in power and dominate every battlefield match.
  IGGM - POE 2 0.5.0 Currency Sale for Runes of Aldur League - Grab 8% off Ephraim 1 79 06-18-2026, 04:38 PM
Last Post: divyarawat
  IGGM - Cheap MLB The Show 26 Stubs & Free Giveaways Event Ephraim 2 120 06-12-2026, 04:31 PM
Last Post: vaanibatra
  IGGM | Buy Cheap Monopoly The Simpsons Album Stickers Fast Ephraim 0 66 06-08-2026, 01:00 PM
Last Post: Ephraim
  IGGM - Cheap Diablo4 S13 & Lord of Hatred Items For Sale Ephraim 0 79 06-08-2026, 12:22 PM
Last Post: Ephraim
