Prepping a Restomod for the Open Road: My 500-Mile Charger Adventure
It's 2026, and I'm still tinkering with my 1969 Dodge Charger restomod. Last year, I dropped a BluePrint Engines Gen III Hemi Compatible 426 crate motor in it, paired with a Tremec TKX five-speed from American Powertrain. That was a game-changer compared to the old carbureted 440 and 4-speed. Now, with my annual trip from my home base down to the Outer Banks, North Carolina just around the corner, I'm finding that while the car is way more reliable and comfortable, there's still a ton of prep work to do before I turn the key and hit the highway. Trust me, when you're driving a rolling project like this, you can't just wing it on a 500-mile journey. Over the years, I've learned that the devil is in the details. So, if you're also rushing to get your own project ready for a last-minute summer road trip, let me walk you through my prep process—warts and all.
? Dialing in the Tune: Fuel Injection Perks
Back in the day, I'd be wielding a screwdriver and timing light. Now, thanks to the EFI swap, I just fire up the Holley Terminator X app on my phone. It's a piece of cake to tweak the fuel maps and timing for the best fuel economy. Getting the tune right is a no-brainer before a long trip—you don't want to be burning a hole in your wallet at every gas station. I've been ironing out the tune for weeks, and it's finally in a good place.
[Image: 6a727fa4d6318204db83ec49AePYX6gF07]
?️ Fluids: The Lifeblood of Your Restomod
The motor just had its post-break-in oil change, so that's fresh. But the transmission is due for its first gear oil swap after break-in. I can't stress this enough: always start a long trip with clean fluids. It's cheap insurance for the most expensive hunk of metal you've ever bolted into your car. I'll also top off the coolant and check brake fluid.
[Image: 6a727fb0634697ce6133bc768GNO8ebt07]
⚙️ Suspension & Alignment: No More Wandering
My Charger rides on a Heidts Pro G IFS and a four-link rear with adjustable ride height. I'm always fiddling with settings, but before a road trip, you've got to commit and get a proper alignment. Uneven tire wear and a twitchy ride are not your friends at 70 mph. I set the ride height to where I like it and took it to my alignment guy. Now it tracks straight and true.
[Image: 6a727fbbb394fcf7743c899ciFxPtzJL07]
Cup Holders and Creature Comforts
Here's a first-world problem: classic muscle cars don't have cup holders. For years, I used flimsy universal ones that were about as useful as a screen door on a submarine. This year, I got crafty and hacked a late-model Challenger center console to fit. It wasn't a simple plug-and-play job—I had to cut, bracket, and relocate the shifter—but now I've got a proper spot for my morning coffee. I even wired up the USB ports to keep my phone charged. Creature comforts matter on a long haul.
[Image: 6a727fbf990f1792b53a2b71hIle0Kyj07]
?️ Seeing Through the Storm: Fog Lights
The forecast shows rain on my route, and my Charger had no fog lights from the factory. Night driving in the rain with old-school headlights is sketchy at best. So I added a set of Hella 550 Comet fog lights. They give a bit of period-correct flair, though I'm still on the fence about the look. But safety trumps style when you're caught in a downpour.
[Image: 6a727fca396ccea8868f7ed8PbMlQIVG07]
? Tools and Spares: Be Your Own Roadside Hero
This is where the rubber meets the road. I packed a full-size spare, a jack, and a lug wrench—non-negotiable. But I also threw in a stash of fuses, a multimeter, some basic hand tools, and spare parts that tend to fail on old Mopars: starter relay, ballast resistor, distributor cap and rotor, and plug wires. A portable jump starter and a tire inflator live under my trunk floor now. You can't plan for every breakdown, but you can sure as heck be ready for the common ones.
[Image: 6a727fcdcc67efb0654f8af6h6qRUU8907]
?️ Route Planning: Think Beyond the Shortest Path
I'm not just looking at Google Maps and calling it a day. I consider the location of auto parts stores along the way in case I need a part. I also make sure my route doesn't leave me stranded 30 miles from the nearest civilization if something breaks. I've got roadside assistance with towing coverage, and I've stashed a GPS tracker in the car just in case the unthinkable happens. When I stop overnight, I pick well-lit, secure parking—not some sketchy motel lot where a classic Mopar would stick out like a sore thumb.
[Image: 6a727fd5afbca5ce24787987ZgUb5uUi07]
? Slow and Steady: Don't Rush the Prep
It's easy to get wrapped up in the excitement and try to rush out the door. But I've learned the hard way that skipping a double-check can leave you stranded. I go over everything twice—fluids, bolts, wiring, tire pressures. That way, if something does go wrong, it'll likely be a minor hiccup I can fix on the shoulder. Then it's time to drop the hammer and enjoy miles of open road with the Hemi singing. There's nothing quite like it.
These steps aren't unique to a '69 Charger restomod. Any classic or project car will benefit from the same kind of love before a long trip. So wrench away, pack smart, and hit the road with confidence. After all, isn't that why we build these beasts?
[Image: 6a727fe10c93ea56cc6bf7a70wSaMdEd07]
When you're not on the road or under the hood, it's always nice to unwind with a good game to recharge your mind. Whether you're into classic racing sims that let you relive the glory days of muscle cars or just need a break from the grease and gears, gaming can offer a great escape. And if you're looking for the best deals on your favorite titles, you might want to check game prices at DealNest, where you can find great options to fuel your need for speed or any other gaming adventure.
