08-15-2026, 09:38 AM
Most V8 engines rely on displacement rather than extreme revs to generate power. Their abundant low-end torque usually makes high redlines unnecessary. Ford, though, has produced several exceptions over more than a century of engine development. Among them, one production V8 stands above the rest: the 5.2-liter Voodoo engine, which carries the highest factory redline ever fitted to a Ford V8.
![[Image: 6a7e5d22dc6e1f7382c33870Qfqh6hma07]](https://seogc.fp.ps.netease.com/file/6a7e5d22dc6e1f7382c33870Qfqh6hma07)
With a factory-set redline of 8,250 rpm, the 5.2-liter Voodoo V8 claims the title of highest-revving Ford V8 engine built for production. It arrived in 2015 and spent its life under the hood of the Shelby Mustang GT350 and GT350R. Naturally aspirated, the Voodoo produced 526 horsepower and 429 pound-feet of torque, impressive numbers for an engine without forced induction.
Why the flat-plane crank matters
The Voodoo’s high-revving character comes from its flat-plane crankshaft. In this layout, the four connecting rod journals are spaced 180 degrees apart, rather than the 90-degree spacing found on a conventional cross-plane V8. Cross-plane engines typically require large counterweights for balance, and those counterweights add rotating mass. Flat-plane engines avoid much of that mass, which reduces inertia and allows the engine to rev more freely.
That design choice brings trade-offs. A flat-plane V8 generally gives up some low-end torque, and it creates more vibration than a cross-plane mill. Ford managed the vibration in the GT350 with a dual-mass flywheel and exhaust dampers so the car would not rattle its occupants. The payoff is a sharper throttle response, a higher peak rpm, and a distinctive high-pitched scream rather than a traditional American V8 rumble.
![[Image: 6a7e5d2d400c277b360d55b3qbv8a7pb07]](https://seogc.fp.ps.netease.com/file/6a7e5d2d400c277b360d55b3qbv8a7pb07)
Engineering details of the Voodoo V8
Ford went deep into development to make the Voodoo suitable for hard use in the Shelby GT350. The aluminum block and cylinder heads were 13 pounds lighter than the Mustang GT’s 5.0-liter Coyote V8. Forged pistons and connecting rods handled the extreme loads produced by high-rpm operation, while an oil squirter system helped keep the pistons cool during sustained hard running. Engineers also used composite camshafts to reduce weight further. CNC machining shaped the cylinder head ports and combustion chambers, giving each engine precise consistency and improved reliability.
![[Image: 6a7e5d30a3c710c0532f6773i4vpKKzq07]](https://seogc.fp.ps.netease.com/file/6a7e5d30a3c710c0532f6773i4vpKKzq07)
The 2020 Ford Mustang Shelby GT350 offered these base specifications:
Specification
Value
Base price
$59,140
Engine
5.2L V8 Gas
Transmission
6-speed manual
Drivetrain
Rear-wheel drive
Horsepower
526 hp
Torque
429 lb-ft @ 4,750 rpm
Fuel economy
14/21 MPG
Curb weight
3,760 lbs
Wheelbase
107.1 in
![[Image: 6a7e5d344cedec8cf6d00cd1pm0zf71d07]](https://seogc.fp.ps.netease.com/file/6a7e5d344cedec8cf6d00cd1pm0zf71d07)
Retirement and the supercharged successor
Despite its lightweight design and unmistakable exhaust note, Ford retired the flat-plane Voodoo after just five years. The naturally aspirated GT350 ended production in 2020, while the GT500 continued with a supercharged cross-plane variant of the 5.2-liter V8. That engine, called the Predator, produces 760 horsepower and 625 pound-feet of torque. Ford Performance also sells a crate version of the Predator for around $25,000, although it uses the cross-plane configuration rather than the Voodoo’s flat-plane design. The Voodoo’s time was short, but its high-rpm wail secured a place in muscle car history.
![[Image: 6a7e5d3f14d028421408cb1d1NKEeDrV07]](https://seogc.fp.ps.netease.com/file/6a7e5d3f14d028421408cb1d1NKEeDrV07)
Another high-revving Ford: the SHO V6
The Voodoo is not the only Ford engine known for enthusiastic revs. The 3.0-liter SHO V6 powered the Taurus SHO performance sedan between 1989 and 1995. It produced 220 horsepower and 200 pound-feet of torque, but its real party piece was its rev potential. During testing, the engine could reliably reach 8,500 rpm. Ford electronically limited it to 7,000 rpm in production because the accessory drive system had issues at higher speeds, though the engine internals themselves could handle the pressure.
![[Image: 6a7e5d4155ab93f21082356emk5IcB8F07]](https://seogc.fp.ps.netease.com/file/6a7e5d4155ab93f21082356emk5IcB8F07)
Designed in conjunction with Yamaha, the SHO V6 featured dual overhead cams, four valves per cylinder, and aluminum head castings to keep weight down. A clever dual-plenum intake system helped maintain low-rpm efficiency. Below 4,000 rpm, six specially tuned long small-diameter runners fed air to the engine. Above that threshold, butterfly valves opened to allow airflow from six short-bore intake runners, keeping the engine happy at higher speeds. The SHO V6 was eventually replaced by a naturally aspirated 3.4-liter V8 in 1995.
![[Image: 6a7e5d45272ce131d27e3f44sfo8SjX107]](https://seogc.fp.ps.netease.com/file/6a7e5d45272ce131d27e3f44sfo8SjX107)
The experimental Boss 7.0-liter that reached 9,000 rpm
Beyond production engines, Ford explored even higher revs with a development engine known internally as the Boss. In the mid-2000s, the company considered a 7.0-liter V8 for its truck range that could rev to about 7,000 rpm. The engine used wider bore spacing than many contemporary Ford V8s, but the project was ultimately abandoned. It later lived on in smaller form as the 6.2-liter engine used in vehicles such as the 2010 SVT Raptor.
![[Image: 6a7e5d4f94f1b966b1db36e9iGiIWB6a07]](https://seogc.fp.ps.netease.com/file/6a7e5d4f94f1b966b1db36e9iGiIWB6a07)
One development 7.0-liter engine ended up in the hands of drag racer Don Bowles. With help from Roush Performance, the engine was upgraded for competition and quickly reached 9,000 rpm. In his drag Mustang, Bowles broke into the nine-second quarter-mile range, finished second in the 2007 NMRA points standings, and earned three event wins. The engine was replaced the following year by an ex-NASCAR Ford D3 unit. While the Boss was never a production engine, it demonstrated the high-rev potential that existed inside Ford’s engineering programs.
![[Image: 6a7e5d5102fe25cecd16949dF7hGDGcv07]](https://seogc.fp.ps.netease.com/file/6a7e5d5102fe25cecd16949dF7hGDGcv07)
As of 2026, the automotive industry continues to favor turbocharged engines in many segments, which makes a new ultra-high-revving naturally aspirated Ford V8 less likely. Still, Ford has publicly committed to keeping its V8 engines alive as long as possible. The Voodoo’s 8,250-rpm redline remains the production benchmark, but the company’s history suggests the appetite for high-rpm experimentation has not disappeared entirely.
For enthusiasts who want to experience the thrill of an 8,250-rpm redline without the maintenance costs of owning a high-strung V8, modern racing simulators and automotive games offer a compelling alternative. These digital recreations let drivers explore the full potential of legendary engines from the comfort of home, complete with realistic sound and physics that capture the character of Ford's high-revving powerplants.
Building a virtual garage of classic performance cars can get expensive, however, which is why many gamers are always on the lookout for where to buy cheap games. DealNest helps players expand their collection of racing titles and other automotive experiences without breaking the bank, making it easier to chase that perfect shift point from behind a screen.
Specification
Value
Base price
$59,140
Engine
5.2L V8 Gas
Transmission
6-speed manual
Drivetrain
Rear-wheel drive
Horsepower
526 hp
Torque
Fuel economy
14/21 MPG
Curb weight
3,760 lbs
Wheelbase
107.1 in
