Silksong Patch 1.0.28626 Fixes Bugs While Speedrunners Rewrite Pharloom
The kingdom of Pharloom had barely settled into its rhythm when Team Cherry spoke again.
It was the first week after Hollow Knight: Silksong finally escaped into the wild, and players were still counting their deaths against Moorwing. That first patch had arrived like a merciful hand, trimming the thorns for the early game. But the second patch, numbered 1.0.28626, carried a different message: no more hand-holding.
[Image: 6a5eb8fba53274dead962d8102WYPXIi07]
When the notes went live, the update itself had not yet rolled out. The developers made clear that the most common issues from launch had been handled in the first wave. What remained were the stranger wounds, the ones that only appeared after thousands of players had pressed into every corner of the map. A knight who had struggled early would not find softer bosses here. Instead, the team promised something closer to surgical repair.
The first patch had split the community. Some players praised Team Cherry for making the opening hours less punishing. Moorwing and Sister Splinter were pulled back, their attacks no longer chewing through unprepared travelers quite so quickly. Rosaries became a little easier to find in those early chambers. For many, this was a relief. For others, it felt like an insult to the very idea of Silksong. They had waited years for a challenge, and now the game was softening itself after only a few days.
By the time the second patch notes appeared, however, those voices could relax. Team Cherry listed fixes that had nothing to do with mercy. They were about correctness. A boss could not be allowed to wander out of bounds. A cursed hint had to play properly. A weapon had to behave the way it was designed to behave.
Consider the details:
?️ Shrine Guardian Seth will no longer stray out of bounds during battle. Players who found the guardian suddenly sliding through a wall will now face a fair fight inside the arena.
?️ Certain NPCs will now play their cursed hint dialogues correctly. The whispers, glitches and cryptic lines should land the way the story intended.
? Curveclaw will stop breaking on the first hit after being deflected. A tool that shatters immediately is not a difficulty feature; it is a technical failure.
?️ A cocoon will no longer appear somewhere inaccessible. If a player ever lost their progress because the cocoon sat behind a locked door or beneath the ground, it was not their fault.
[Image: 6a7d0bdb5aaf5b34c60cab3fNMGAXBA807]
That last fix deserves attention. It was one of the only changes that could make the game easier in very specific cases, but only because it corrected a bug. Team Cherry wanted players to understand this clearly. If a cocoon spawned out of reach, the player was not bad at the game. The game was simply breaking its own rules. This kind of honesty mattered in a community already inflamed by difficulty debates.
Even with the early nerfs, Silksong remained brutally hard. A casual player might spend two hours on a single boss, learning each pattern through dozens of deaths. Meanwhile, the speedrunning community was already dismantling the game. Racers had completed the entirety of Pharloom in less than 90 minutes. While one traveler seethed at Groal the Great, another was resetting a run because a single jump had cost three seconds.
[Image: 6a7d0be44f7e4537219737bbWpVBVHpp07]
The patch table made the contrast clear:
Aspect
First Patch
Second Patch
Early game difficulty
Reduced
Unchanged
Boss nerfs
Moorwing, Sister Splinter
None
Rosary visibility
Improved in early stages
No change
Bug fixes
Major launch issues
Critical edge cases
By 2026, the question was no longer whether Silksong would be fixed. It was how high the skill ceiling could go. The scoreboards promised something extraordinary. The early boss nerfs had given newcomers a foothold, but the second patch made clear that the deeper game would not be sanded down. If Moorwing still caused trouble, that was on the player now. Git gud, as the developers might say with a wry smile, but only after they had made sure the walls were solid and the cocoons were reachable.
The story of Silksong's first year became less about bugs and more about two different kinds of players. One group crawled through Pharloom, learning each death like a verse. The other flew through it, turning the map into a stopwatch. The second patch did not try to unite them. It simply repaired the world beneath their feet, so both kinds of struggle could be fair.
For players on either side of that divide, the practical question of how to step into Pharloom remains. Whether the goal is to beat the entire map in record time or to edge past just one more boss, the journey costs the same entry fee. Taking a moment to check game prices before grabbing a copy is a small step that mirrors the game's own philosophy—preparation matters, and informed choices make for smoother progress.
The game's evolving patches have only deepened its long-term value. Every fix, every rework, and every fairer spawn point adds durability to a world that players will return to for years. That makes a smart purchase more than just a bargain; it becomes a foundation for the countless hours of challenge, discovery, and quiet triumph that Silksong promises to anyone willing to learn its rhythms.
  Silksong Confessions: Stubborn, Broke, and Still Hugging Every Wall in Pharloom xtameembb 0 10 Today, 02:23 AM
  Silksong Confessions: Stubborn, Broke, and Still Hugging Every Wall in Pharloom xtameembb 0 16 Yesterday, 10:21 AM
  Pharloom Kept These Silksong Secrets From Me Until My Third Run xtameembb 0 15 09-02-2026, 11:49 AM
  Pharloom Kept These Silksong Secrets From Me Until My Third Run xtameembb 0 18 09-01-2026, 05:53 PM
  Silksong Patch 2: Team Cherry Fixes Bugs, Keeps the Pain Deliciously Intact xtameembb 0 95 08-21-2026, 08:03 AM
  Silksong Patch 2: Team Cherry Fixes Bugs, Keeps the Pain Deliciously Intact xtameembb 0 94 08-21-2026, 04:59 AM
  Team Cherry Reveals Second Hollow Knight: Silksong Patch with Fixes and Clarity xtameembb 0 96 08-21-2026, 01:44 AM
  Team Cherry Reveals Second Hollow Knight: Silksong Patch with Fixes and Clarity xtameembb 0 107 08-20-2026, 12:30 PM
  I Visited the Hollow Knight: Silksong Exhibit and Discovered Pharloom’s Lost Secrets xtameembb 0 135 08-11-2026, 04:28 AM
  How to Get the Hunter's Journal and Complete Bugs of Pharloom in Silksong xtameembb 0 148 07-31-2026, 03:36 PM
