How to Get the Clawline Grappling Hook in Hollow Knight: Silksong
Every so often, a single movement tool turns a Metroidvania from a pleasant wander into a physics-defying joyride. Hornet’s Clawline in Hollow Knight: Silksong is exactly that item. On paper it sounds modest: a grappling hook that lets her zip to dedicated hooks, latch onto distant walls, and stretch her dash far beyond its usual limits. In practice, it transforms tight corridors into personal zip lines and hidden alcoves into trivial pit stops. So where does this gloriously handy string launcher live? And why does fetching it involve a bell, a merchant, a white key, and what feels like a lava-themed endurance test? The answer lies beneath the Citadel, inside the Underworks.
[Image: 6a864642f936ea300fc6cc75aexLfzq307]
Why the Clawline Is Worth the Detour
The Clawline is one of those abilities that players may overlook because it does not delete bosses; instead, it deletes the space between Hornet and wherever she wants to go. While dedicated Weaver skills often grab the spotlight in combat, the Clawline earns its place because it is required for accessing several areas and secrets across Pharloom. It also doubles as a combat tool: Hornet can zip around enemies, dodge incoming attacks, and reset her positioning mid-fight. Is it the flashiest tool in the kit? Not always. Is it one of the most versatile? Absolutely.
Prerequisites: Do Not Show Up Empty-Handed
Before anyone goes spelunking for the Clawline, a few boxes need to be ticked. The biggest gate is story progress: the player must have beaten the Last Judge and unlocked Act 2 of Silksong. Without Act 2, the Citadel route leading to the Clawline remains closed, and no amount of wall jumping will change that.
After that, the path becomes a checklist:
Requirement
Why It Matters
Beat the Last Judge
Unlocks Act 2, which opens the Citadel route
Reach the Citadel
Where the key, the Songclave camp, and the Underworks are found
Establish the Songclave camp
Must be set up at the north-east end of the Citadel
Ring the bell and complete the first Wandering Merchant quest from the Wishboard
Makes the White Key available for purchase
Buy the White Key from Jubilana
Required to unlock the elevator blocking the Underworks
[Image: 6a86464ebc6200ffb70594fbH6iPs5SK07]
Getting the White Key
Once the Songclave camp is established at the north-east end of the Citadel, players should ring the bell and complete the first Wandering Merchant quest from the Wishboard. Only then will Jubilana sell the White Key. This little item is not optional—it is the very thing that unlocks the Ornate Lock blocking the elevator deep in the Choral Chambers.
After buying the key, the next step is to backtrack. Head down to the bottom end of the Choral Chambers in the Citadel and look for the Ornate Lock. Using the White Key on that lock frees the elevator, which leads into the depths. From there, the journey continues as far right as possible until an upper vent appears. That vent drops Hornet into the newly unlocked Underworks.
Surviving the Underworks Without Becoming Crispy
If the Citadel felt civilized, the Underworks quickly reminds everyone that Pharloom has a molten personality. The area is packed with lava traps and environmental hazards, and at least two obstacles can chew through Mask health in a hurry. Reckless players will learn the hard way that this is not a place for casual strolling.
A few survival tips:
Build silk on nearby enemies before descending. Having silk on hand gives Hornet more options and reduces the temptation to panic.
Use pogo attacks and dashes to cross the Cauldron’s lava pools. A well-timed pogo can keep Hornet airborne long enough to avoid the worst of the heat.
Loop around the edge of the shrine area. The Clawline shrine sits in a circular layout, and the safest approach often involves going around it rather than charging straight through.
[Image: 6a86465a2dde3f371d88e52896c3AI5d07]
Once Hornet reaches the shrine and claims the Clawline, it acts as a true grappling hook. She can immediately grab onto nearby hooks to escape the area and continue deeper into Pharloom. That moment of first zipping out of the Underworks is, frankly, worth every lava singe.
What the Clawline Actually Does
The Clawline is not just a fancy key for the Underworks exit. Its real value shows up after leaving the shrine:
Grappling traversal: Hornet can latch onto dedicated hooks scattered throughout Pharloom.
Extended dashes: The Clawline drastically increases her dash distance.
Wall latching: She can grab onto far-away walls, opening routes that once looked impossible.
Combo movement: It pairs beautifully with pogo attacks and Hornet’s floating ability. Together, these tools let players reach much farther distances and uncover hidden secrets that would otherwise remain out of reach.
Could a pure combat skill out-damage the Clawline in a straight fight? Sure. But those skills will not open secret routes, skip environmental hazards, or turn Hornet’s movement into a silk-powered slingshot. The Clawline earns its place in the toolkit because it expands what traversal can even mean.
Final Word
Players who rush straight to the damage-dealing toys may miss the Clawline entirely, but that would be a shame. Few abilities in Hollow Knight: Silksong feel as satisfying to use while exploring, escaping, or simply showing off. Beat the Last Judge, establish the Songclave camp, complete that first Wandering Merchant quest, buy the White Key, and brave the Underworks. For 2026 explorers of Pharloom, the reward is still a movement option that makes the rest of the kingdom feel suddenly much smaller.
Silksong's 2026 window means players have time to prepare — not just in-game, but financially too. Hornet's journey through Pharloom will undoubtedly be worth the wait, but no one should pay more than necessary for the privilege of exploring it. For players wondering where to buy cheap games, DealNest tracks prices across digital storefronts so you can grab a copy the moment a discount appears, without endlessly refreshing multiple shops.
Being a savvy explorer is about more than mastering the Clawline or timing a perfect pogo; it's also about making smart choices before the adventure even begins. A quick price check takes seconds, and the savings can go toward other upcoming releases — or simply serve as a reminder that patience pays off, both in Pharloom and on your wallet.
  My Journey Through Every Hollow Knight: Silksong Ending xtameembb 0 30 Yesterday, 06:49 PM
  I Ranked Every Silk Skill In Hollow Knight: Silksong xtameembb 0 26 Yesterday, 05:30 PM
  Hollow Knight: Silksong – Grand Mother Silk Boss Strategy and Extended Ending Guide xtameembb 0 28 Yesterday, 06:47 AM
  That Time a Mouse Cursor Became Hollow Knight: Silksong's Unlikely Canon Star xtameembb 0 29 Yesterday, 06:08 AM
  A Player's Guide to Surviving Groal the Great in Hollow Knight: Silksong xtameembb 0 32 Yesterday, 04:08 AM
  A Player's Guide to Surviving Groal the Great in Hollow Knight: Silksong xtameembb 0 28 Yesterday, 01:45 AM
  Hollow Knight: Silksong Lost Lace Guide: Builds, Phases, and Void Dodging xtameembb 0 32 Yesterday, 12:30 AM
  Hollow Knight: Silksong – Grand Mother Silk Boss Strategy and Extended Ending Guide xtameembb 0 35 08-22-2026, 10:55 PM
  That Time a Mouse Cursor Became Hollow Knight: Silksong's Unlikely Canon Star xtameembb 0 35 08-22-2026, 01:17 PM
  Hollow Knight: Silksong Lost Lace Guide: Builds, Phases, and Void Dodging xtameembb 0 37 08-22-2026, 12:47 PM
