Silksong Final Audience Quest: Locating and Defeating the Second Sentinel
As Hornet ventures through the second act of Silksong, a seemingly minor curiosity in the form of a Cogwork Heart Piece can pull attention away from the primary path. Each recovered fragment feeds into a larger side quest that ultimately revives a Citadel protector and opens the door to the Final Audience. Completing this chain awards the Reserve Bind, a tool many players consider one of the most valuable assets in the entire game.
[Image: 6a8797a2710b8a5f30f39326ZZ90r2i207]
How to Start Final Audience
The Final Audience quest is not immediately available from the Songclave job board. A substantial checklist must be satisfied before the posting appears.
Collect all three Cogwork Heart Pieces scattered across Pharloom and bring them to Cogwork Core, where the Cogwork Heart revives the Second Sentinel.
Obtain the Clawline and Faydown Cloak, as these abilities grant access to the pieces and the later boss area.
Explore and clear the High Halls, because the duel takes place in its lower levels.
Witness two distinct encounters where the player fights alongside the Second Sentinel. The first occurs in the long corridor connecting the upper Cogwork Core entrance—the same place where the Cogwork Dancers and Songclave were fought. The second takes place in the long hall at the bottom of the Choral Chamber.
Collect the threefold melodies needed to travel to The Cradle.
Only after all these steps are completed will the Final Audience quest appear on the Songclave job board.
Where Is the Second Sentinel?
[Image: 6a8797a91cbc9416d3cc84dc4roYQ6rG07]
After the prerequisites are handled, the Second Sentinel can be found in a secret room within the High Halls. The route uses the shortcut that rises directly to the bench near the forum, then follows the tracker trail exiting the top right of that screen. The sentinel waits in the hidden room to the right and initiates the fight after a brief conversation.
How to Beat Second Sentinel
The Second Sentinel is an aggressive duelist with movements that echo Lace, though the encounter is generally more demanding than the Cradle battle against Lace.
The opening attack often begins with a cross-shaped telegraph. An X flashes on screen before an explosion of light expands across a larger X pattern. The safest response is to retreat and occupy the spaces between the arms of the cross.
The base moveset includes jump-and-diagonal lunges, thrusting attacks that close distance, and a parry counterattack that unleashes a rapid flurry of stabs. A more distinctive spinning leap sends a wave of light projectiles across the arena.
Attack
Description
Suggested Response
Cross Explosion
X telegraph, then large X light burst
Back off into spaces between arms
Jump or Diagonal Lunge
Closing leaping slash
Move away or under, then punish
Thrust Chain
Multiple rapid stabs
Continue dodging; do not counter early
Parry Counter
Flurry after blocking player strike
Avoid careless attacks near block
Spinning Leap Projectiles
Spins and casts light wave
Jump or hover to avoid projectiles
What makes the boss dangerous is adaptability. Thrusts do not end when avoided; they chain into multiple follow-up stabs. Leaping attacks shift to track the player's movement, preventing easy dodges by reading a locked animation. The sentinel rarely backs off, making healing windows scarce.
Because there is no obvious weakness, the best approach is to use the arena's verticality. Hovering near a wall to heal can create safer moments. In the final phase, spending stored shards on ranged tools can shorten the fight. Constant movement and small, patient hits are more reliable than trying to force an opening.
Rewards for Completing Final Audience
[Image: 6a8797b3681031ecc8e099dftvaDqHaT07]
After the Second Sentinel falls, they leave behind the Reserve Bind. This blue-coded tool grants one additional reserve of silk that can be used for healing at any time, even when the normal silk supply is too low to heal normally.
In tense fights where gathering silk is impossible, the Reserve Bind offers a comeback option. Players can activate the backup reserve and return to the offensive instead of waiting for a safe healing window. Combined with the satisfaction of finishing the Final Audience chain, it is a reward that justifies the lengthy setup.
Completing the Final Audience chain is a memorable milestone, and the thrill of conquering the Second Sentinel often leaves players hungry for more demanding action games. If you are looking to expand your library with similar titles, checking store prices is always a smart first step before committing to a purchase.
For those ready to move on to the next challenge, DealNest offers a convenient way to track prices across multiple storefronts. Its game price comparison helps you spot discounts and compare editions, so you can spend less time shopping and more time enjoying your next brutal encounter.
  Silksong Final Audience Quest: Locating and Defeating the Second Sentinel xtameembb 0 31 Yesterday, 03:52 AM
  Hollow Knight: Silksong – Crawbug Clearing Wish Quest and Ragpelt Farming Guide xtameembb 0 55 08-20-2026, 09:26 AM
  Hollow Knight Silksong Advanced Alchemy Quest Walkthrough and Secret Boss xtameembb 0 68 08-19-2026, 09:58 AM
  Silksong: A Cheeky Guide to the Green Prince Quest and Lost Verdania xtameembb 0 71 08-19-2026, 04:34 AM
  Hollow Knight: Silksong – Crawbug Clearing Wish Quest and Ragpelt Farming Guide xtameembb 0 70 08-18-2026, 08:56 PM
  A Journey Through Silksong's Cogwork Heart and the Second Sentinel's Trial xtameembb 0 51 08-18-2026, 08:25 PM
  Hollow Knight Silksong Advanced Alchemy Quest Walkthrough and Secret Boss xtameembb 0 61 08-18-2026, 07:24 PM
  A Journey Through Silksong's Cogwork Heart and the Second Sentinel's Trial xtameembb 0 54 08-16-2026, 06:25 PM
  Guide to the Steel Soul Exclusive Quest: A Vassal Lost in Hollow Knight: Silksong xtameembb 0 72 08-15-2026, 09:02 AM
  Guide to the Steel Soul Exclusive Quest: A Vassal Lost in Hollow Knight: Silksong xtameembb 0 89 08-12-2026, 05:05 PM
