08-25-2026, 02:56 PM
Nobody picks up a wailing, vine-covered baby for fun—except the most stubborn completionists in Hollow Knight: Silksong. The Rite of Rebirth sounds like a noble wish, but it quickly turns into a multi-zone scavenger hunt that strips Hornet of her healing, her tools, and her patience. Here is how Hornet can survive the ordeal without losing her mind.
Finding the Twisted Bud
The Twisted Bud sits in a cradle on the outskirts of Bilewater, hidden behind tiny passageways. To reach it, Hornet needs the grappling hook from the Whispering Vaults in The Citadel. From there, she should head east, pull down a hook, dodge a series of very rude gears, and drop into Bilewater. After progressing a little east, she must look for a hidden path on the left near the bottom. Small side paths eventually lead up and to the right, where the cradle waits.
The real problem starts after pickup. The Twisted Bud is described as consorted mass of ashen vine. Cries out incessantly. Opening the inventory becomes psychological warfare, because the bud screams every single time.
Greyroot’s “Help” Is a Trap
After grabbing the bud, Hornet heads to Greyroot. Players who completed the Rite of Pollip will gain access to the Rite of Rebirth. It sounds like a wholesome delivery. It is not.
Greyroot accepts the Twisted Bud, grabs Hornet, infects her with a parasite, and drops her at the Chapel of the Witch in Shellwood. So much for maternal warmth. The infection imposes three miserable restrictions:
? Cannot change Crests
?️ Cannot equip tools
️? Cannot Bind or heal
That final restriction hurts most. Every skirmish turns into a no-hit challenge. There is one upside: finishing the game while infected opens a different ending. Most first-time players, however, will want the parasite gone before the controller goes through a window.
Curing the Infection
The easiest lead comes from the Bell Hermit in Bellhart. He tells Hornet to seek an exiled bug named Yarnaby, who has moved “high up into the moors.”
Yarnaby lives in the northwest of Greymoor. Hornet must climb the towers, push all the way west, and eventually reach a small home belonging to a rather rude individual: Yarnaby. After Hornet explains the illness, Yarnaby agrees to help, but only in exchange for a specific item: Steel Spines.
Yarnaby’s directions are deliberately vague—“a tangled mess of cages.” Players who have visited Sinner’s Road will recognise the cages in the central section. At the top right of that area, two bugs named Benjin and Crull wait. They will sell the Steel Spines for 260 Rosaries.
Item
Cost
Location
Steel Spines
260 Rosaries
Benjin & Crull, Sinner’s Road central cages
Return to Yarnaby with the Steel Spines, and she will rip the parasite out of Hornet with zero bedside manner. The reward is the Witch crest, plus the return of healing and tools. The Twisted Bud’s crying finally stops.
Final Tips for the Rite of Rebirth
? Save 260 Rosaries before visiting Benjin and Crull.
? Avoid opening the inventory while carrying the cursed bud.
? Explore Sinner’s Road early to mark the cage location.
? If attempting the infected ending, do it on a second run, not the first.
The Rite of Rebirth is less about rebirth and more about being repeatedly inconvenienced across Pharloom. But the story, the Witch crest, and the sweet sound of silence after the parasite is removed make it one of Silksong’s most memorable detours.
Once the parasite is gone and the Witch crest is equipped, the rest of Silksong opens up at your own pace. For many players, finishing this quest is also a signal to revisit other parts of Pharloom — or to start hunting for similar action-platformers with the same rich atmosphere. Whether you're picking up a physical copy of Silksong, investing in a new controller, or eyeing expansion packs, every Rosary saved at Benjin and Crull reminds us that frugality pays off.
That same mindset carries over into real-world gaming purchases. Before committing to a full-price order, it's worth checking whether a better offer is hiding nearby — just like a secret room in Greymoor. DealNest regularly rounds up discounts, promo codes, and bundles across the gaming and tech space, so you can spend less time hunting for bargains and more time actually playing. A little patience rewards exploration in Hallownest, and it can do the same for your wallet.
Item
Cost
Location
Steel Spines
260 Rosaries
