How to Get the Barbed Bracelet in Hollow Knight: Silksong and Is It Worth It?
In Hollow Knight: Silksong, Hornet's expanding collection of Tools grants players flexibility for every combat and platforming challenge. Some Tools improve movement, others grant defensive benefits, and a few trade safety for raw damage output. The Barbed Bracelet falls into that last category. While most damage upgrades require tracking down Pale Oils and returning them to Bellhart, this hidden Yellow Tool increases Hornet's needle damage but also increases the damage she receives. For players exploring the 2026 builds of the game, the Barbed Bracelet remains one of the most debated Tools in Hornet's loadout.
The Barbed Bracelet is hidden deep enough that players cannot grab it during the opening hours. The first requirement is reaching Shellwood and unlocking the Wall Jump ability. That means defeating Sister Splinter and then moving right from the boss arena to collect the ability. Without Wall Jump, the vertical climbs and spike-filled corridors leading to the bracelet are not accessible.
Once Wall Jump is available, travel to Greymoor Bellway Station. Head left and enter the first tower. From there, climb upward until a passage on the right appears. Follow that passage into the second tower, then continue moving right and take the passage on the right. This is where the platforming becomes tighter: from the elevator, pogo off the metal spikes on the left, float toward the right, and use a down slash on a ball to reach the top-right exit. The passage leads directly into Sinner's Road.
Inside Sinner's Road, ignore the imprisoned green mantis above and push far to the right. The route passes through a room filled with multiple Muckroaches. At the end of that room, do not take the path going upward. Instead, enter the cage and drop down carefully. After avoiding the spikes, players will find the Barbed Bracelet resting on top of a wooden raft.
[Image: 6a93753c4cca70ede6f6cc84kDMjI9UX07]
How the Barbed Bracelet Works
The Barbed Bracelet is a Yellow Tool with a simple but risky effect. It increases Hornet's total damage output, and it also increases the damage she takes. That double-edged design makes it very situational. Because most players will have fewer than eight Mask Shards before reaching the endgame, the higher incoming damage often means that bosses can two-shot Hornet. This is especially dangerous in fights with fast combos or delayed attacks that are difficult to learn quickly.
Platforming sections are even more punishing with the bracelet equipped. Many enemies, wall spikes, and environmental traps already deal two Mask damage without any extra penalty. With the Barbed Bracelet equipped, a single mistake can send Hornet back to the bench in under a minute. For that reason, it is not recommended for blind exploration, difficult platforming gauntlets, or any boss fight where the player is still learning attack patterns.
That said, the Barbed Bracelet is not without value. Against predictable bosses where players are confident in their ability to avoid hits, the damage boost can shorten fights significantly. Fewer attack cycles mean less time in danger and more room for mistakes overall, which can offset the risk for skilled players.
Is It Worth Equipping?
The Barbed Bracelet has a clear niche, and it shines most when players are farming for Rosaries. On farming routes, taking one or two hits is common, but the bracelet allows Hornet to clear enemies much faster. Pairing the Barbed Bracelet with the Fractured Mask creates an especially effective setup, because the extra survivability lets players withstand three hits while still benefiting from the boosted damage. The result is a faster and safer farm loop.
The bracelet also has synergy with the Clawline ability once it is unlocked. Since the Barbed Bracelet increases Clawline damage as well, players can harpoon enemies and dash away repeatedly. This hit-and-run style makes most Rosary farming routes easier and noticeably shorter. Instead of committing to long melee trades, players can kill from range and reposition before enemies can respond.
? Best use cases: Rosary farming, predictable bosses, experienced players who rarely get hit
️ Avoid using in: platforming-heavy areas, multi-phase boss fights, early-game loadouts
?️ Pairs well with: Fractured Mask, Clawline ability
Final Verdict
The Barbed Bracelet is a high-risk, high-reward Tool that rewards careful planning and confident play. It is not a universal best-in-slot item, and players who prefer a defensive or exploration-focused build should leave it unequipped for most of the game. However, once a farming route is established or a boss pattern is fully learned, the damage increase becomes a powerful tool for saving time and ending fights quickly.
For players exploring Hollow Knight: Silksong in 2026, the Barbed Bracelet is absolutely worth collecting once the route to Sinner's Road is open. The acquisition requires solid Wall Jump control and some precise spike pogoing, but the payoff for Rosary farming and confident boss kills makes the detour worthwhile.
Of course, an efficient build only matters if you actually have the game in your library. Players who enjoy fine-tuning their loadouts in Silksong often apply the same careful planning to how they buy games. Timing purchases around seasonal sales can make a big difference, and staying informed about the best ongoing offers is a smart habit for any PC player.
For those looking to expand their collection without overspending, keeping an eye on PC game discounts is a practical way to spot worthwhile deals early. A little patience between sales can free up budget for other indie gems while you keep mastering Hollow Knight: Silksong.
  Hollow Knight: Silksong Crowns Xbox Game Pass's Unstoppable 2025 Hot Streak xtameembb 0 10 1 hour ago
  All 18 Spool Fragment Locations in Hollow Knight: Silksong (2026 Guide) xtameembb 0 12 6 hours ago
  How I Got Hollow Knight: Silksong's Cursed Ending While Bearing the Twisted Bud Curse xtameembb 0 16 7 hours ago
  Hollow Knight: Silksong Crowns Xbox Game Pass's Unstoppable 2025 Hot Streak xtameembb 0 26 Yesterday, 06:31 PM
  How I Beat Trobbio in Hollow Knight: Silksong Act 2 xtameembb 0 26 Yesterday, 12:57 PM
  Silksong Frustrations? Cure Them With Hollow Knight and a Comfort Sitcom xtameembb 0 25 Yesterday, 05:09 AM
  Silksong Frustrations? Cure Them With Hollow Knight and a Comfort Sitcom xtameembb 0 41 09-03-2026, 02:24 PM
  Every Mask Shard Location I Found in Hollow Knight Silksong xtameembb 0 36 09-03-2026, 07:21 AM
  Every Mask Shard Location I Found in Hollow Knight Silksong xtameembb 0 34 09-03-2026, 03:45 AM
  How to Get Volt Filament in Hollow Knight: Silksong xtameembb 0 43 09-02-2026, 02:06 PM
