What are the first things you check when a heavy-duty truck develops a mechanical
Hi everyone, I’m interested in hearing how other mechanics and technicians approach heavy-duty truck problems. When a truck starts losing power, making unusual engine sounds, overheating, or showing a warning light, what do you check first?
I usually start with the basics such as fluid levels, visible leaks, electrical connections, fault codes, and signs of overheating before moving into more detailed diagnostics. What troubleshooting steps have worked best for you?
  What are the first things you check when a heavy-duty truck develops a mechanical jameslucas 0 19 09-02-2026, 06:56 AM
Last Post: jameslucas
Noregon JPRO a good heavy duty truck scan tool KBT460 1 1,800 11-18-2024, 11:08 PM
Last Post: Paul Zagata
  6 Things to Look Out for with a Heavy-Duty Truck Scan Tool": Daysi 0 1,043 02-04-2024, 11:59 PM
Last Post: Daysi
  2022 v3 latest JPRO Professional Heavy Truck Diagnostic Tool Martin56 0 2,528 02-11-2023, 08:44 PM
Last Post: Martin56
